I wish people would do more AMM-1 testing. I have put out a lot of amps numbers using an AMM-1 so you know what you're actually seeing in a real world scenario.
You would only know what you're seeing in your real world scenario which will not be the same for everyone.
Well you would know if someone says XXXX amp can't do YYYY power, and I show the amp doing it in my car, that they were in fact wrong and that it can happen in a real world scenario.
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
Nice amp for sure.
I just have a quick question.
What exactly is the dynamic test?
I mean it seems a little odd.
It seems to me like a possible 1 sec number, when lightning strikes, like a max rating.
Nothing against the amp. Nothing against the test either. Im sure the test is accurate and has its validity, but I cant see where that applies for most of us. Its like an in kick SPL score for us window guys. The score is still valid in its own right, but its not really meaningful to our standard of scoring.
If that makes any sense.
This is what they say in the literature :
"In Dynamic Power Mode the AD-1 uses industry standard bursted signals and captures the power generated by the amplifier during these quick bursts. The high speed microprocessor and patent pending clipping detection system working seamlessly together are able to read the clean "RMS" power output from the amplifier during these very short bursts. (20mS for the 1kHz test, and 100mS for the 40Hz test)"
So the power is still relatively clean (un-clipped) but is only measured over a short time -- basically a "burp" power assuming no impedance rise from what you select on the machine.
We included it since a ton of other tests already posted on YouTube have this information; and I know someone would ask if it was not included.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Nice amp for sure.
It's a great test.. please include it in all of the tests!
Yea thats true everyone shows all three scores so might as well.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
ive been saving up for a saz3500dV2.......might just have to transition to the scv4000 !!! the 4000 is more affordable, and puts out crazy numbers! I see adding batts to the bank in the near future! way to go Sundown! you get my vote!
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Would like to see what the saz-3500v2 does on the dyno. Would send 1 of my amps in if need be
05 dodge magnum rt
DEH-80PRS
Rockford fosgate T600.4
st200 tweeters
Sundown Neo Pro 6.5 v2's
2 Saz-3500v2- Toolmaker dual 1/0 inputs
2 Sundown ZV4 12" D1
1/0 Sky High Power wire OFC
3 XS D3100- Toolmaker battery terminals
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
