Sampsonite Posted February 4, 2009 Report Posted February 4, 2009 Progress pics!!! http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif x6 --Sampson 816-591-6592 www.kcrimshop.com
meade916 Posted February 4, 2009 Report Posted February 4, 2009 Nice crimper! Way stronger then a soldered connection So Im gonna guess since you got this crimper your gonna redo all your power wire and all that? Also, I wanna see video proof of them DDs clamped on your new metter!!! it is a nice crimper but if you know how to solder CORRECTLY its not going to be stronger. Id like to see a pull test between one of my soldered connections verse something that was just crimped. IMO- PROPER Soldering>Crimping Solering AND Crimping FTW though..... All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
PULS8 Posted February 7, 2009 Report Posted February 7, 2009 Open door Hairtricks uploading now The contestants: http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif EDIT: Whoops logged in on a friend's computer but you know what I mean -Chugger current SQ car: 98 holden combo jvc usb headunit 4 prv audio bullet tweeters 8 prv audio neo 8" 16 obsidian audio v2 12" woofers 8 crescendo bc2000d 10 120 a/h Schneider agm batts Mechman SMD 350 amp H/O alternator (dual alt setup) All Shok industries cables ..... pretty soft really
Charger Posted February 7, 2009 Author Report Posted February 7, 2009 Vids as promised: http://www.stevemeadedesigns.com/board/ind...showtopic=37812 Previous 150+ daily rides: Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470 2 x Kicked Solo X 18s, Lexus LS400 4 x American Bass HD18 walled SMD - System of The Month August 2008 My Youtube Videos
PULS8 Posted February 8, 2009 Report Posted February 8, 2009 you know what it is current SQ car: 98 holden combo jvc usb headunit 4 prv audio bullet tweeters 8 prv audio neo 8" 16 obsidian audio v2 12" woofers 8 crescendo bc2000d 10 120 a/h Schneider agm batts Mechman SMD 350 amp H/O alternator (dual alt setup) All Shok industries cables ..... pretty soft really
DHFHades Posted February 8, 2009 Report Posted February 8, 2009 it is a nice crimper but if you know how to solder CORRECTLY its not going to be stronger. Id like to see a pull test between one of my soldered connections verse something that was just crimped. IMO- PROPER Soldering>Crimping Solering AND Crimping FTW though..... I actually went to school for electronics assembly, and when we were tested on our solder joints the wire had to break before the joint or you failed that one so no crimp in the world is stonger than a proper solder joint 1990 Jeep Cherokee 4X4 Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp DAT HF1000.1 #007 powering a DC lvl4 15 DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active 1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest. rebuild coming soon to get a better score "I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
PULS8 Posted February 8, 2009 Report Posted February 8, 2009 well l guess me an charger gonna do both then aye current SQ car: 98 holden combo jvc usb headunit 4 prv audio bullet tweeters 8 prv audio neo 8" 16 obsidian audio v2 12" woofers 8 crescendo bc2000d 10 120 a/h Schneider agm batts Mechman SMD 350 amp H/O alternator (dual alt setup) All Shok industries cables ..... pretty soft really
bobo333 Posted February 9, 2009 Report Posted February 9, 2009 damn man those videos are freakin nuts... shoulda left the camera goin a bit longer tho to get their reactions but damn, that shits loud ^^^ clicky pics for build logs ^^^
Boon Posted February 10, 2009 Report Posted February 10, 2009 so no crimp in the world is stonger than a proper solder joint Eeeh not the thread-jack but I disagree. Soldering is, well, soldering. You're just melting some crappy alloy around the wire. A proper crimp done with a hydro crimper like Charger's will achieve what is called a cold weld, where the metals actually fuse completely. If you cut open a properly crimped lug you will find the strands of the cable have turned into a solid lump of copper. The final result is exactly the same as if you had heated the metals to melting point and allowed them to cool again, just like regular welding. If you think soldering is stronger than welding... http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.gif 10.x volts fo' life!
Charger Posted February 10, 2009 Author Report Posted February 10, 2009 Copper to copper, one of the best connections available. Full 360degrees around the wire connection, I'd be comfortable towing my car up hill with my joint Previous 150+ daily rides: Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470 2 x Kicked Solo X 18s, Lexus LS400 4 x American Bass HD18 walled SMD - System of The Month August 2008 My Youtube Videos
