JustinCapro Posted October 7, 2014 Report Posted October 7, 2014 The problem is erratic sometimes when I listen to bass its like the output is muffled and sometimes it is normal output and very very loud "I compete with this car, and I am a audio installer so no half A** work done to the car" radio and amp tuned with dd-1 and crossover calibrator A crescendo bc3500 stinger battery spv 69 focal rcas dd 9512 dual 1.5 wired to .7 kenwood dnx 890hd Things I have done to troubleshoot the problem Changed the rcas from expert series 8000 stinger rcas to focal pro rcas costed 100$ that didn't help the problem I changed out all my big 3 wire and soldered all connections before it was just crimped. I tested the pre amp output on my radio and and got 5 to 6 volts every time. I tested the resistance of my sub it was .7 Also tested the resistance of my rcas it read below .0 ohms which is good Note* The amp also periodically makes a loud pitched noise it does not come through the sub but it comes from the amp.Please help me troubleshoot my problem it is driving me crazy.
n8ball2013 Posted October 7, 2014 Report Posted October 7, 2014 get some electrical jesus THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
gally Posted October 7, 2014 Report Posted October 7, 2014 i battery for wiring an amp to 0,7? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
JustinCapro Posted October 8, 2014 Author Report Posted October 8, 2014 i battery for wiring an amp to 0,7? Yup ! been with this setup for almost a year no problems
SnowDrifter Posted October 8, 2014 Report Posted October 8, 2014 The noise is coming from the physical amp itself? What's your voltage at the amp when it makes the problem you're describing? What method did you use to set your gains and how did you arrive at your current setting? Possible to get a video of the problem? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Afficionado Posted October 8, 2014 Report Posted October 8, 2014 i battery for wiring an amp to 0,7? Yup ! been with this setup for almost a year no problems Well you clearly have a problem now...do as n8 said... If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
evermaxx Posted October 8, 2014 Report Posted October 8, 2014 lol, and here I am running a 320xp, 3 3100's and a 6500. i wanna see that voltage drop. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
Miguels Posted October 8, 2014 Report Posted October 8, 2014 i battery for wiring an amp to 0,7? Yup ! been with this setup for almost a year no problems wait!! arent you having problems now? thats the reason for this post anyways.. mess with the gains. last year i came across that would do the same. i messed with the game and worked. moved it just a bit and it wouldn't get loud. it was hard to tune it this thread is just so funny Crescendo BC3500 output Problem Troubleshootingi battery for wiring an amp to 0,7? Yup ! been with this setup for almost a year no problems lol sorry man its just too funny to not bring it up my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
timc31610 Posted October 8, 2014 Report Posted October 8, 2014 Took a year for low voltage to damage your amp, I say thats a bad ass amp! My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
JustinCapro Posted October 8, 2014 Author Report Posted October 8, 2014 The noise is coming from the physical amp itself? What's your voltage at the amp when it makes the problem you're describing? What method did you use to set your gains and how did you arrive at your current setting? Possible to get a video of the problem? Yes it comes from the amp but not all the time and I found out today if i push the negative power wire a certain way on the amp i can recreate the buzzing noise.but it does not help the loss of power in the bass. I can have the volume turned all the way down and hear the noise it dont have anything to do with voltage i don't think because from the front battery to the amp there isn't even a .02 voltage difference I would try to get a video but everything is sporadic
