timc31610 Posted October 10, 2014 Report Share Posted October 10, 2014 Hey guys, I have two Soundqubed Q2-200 2 channel amps, one for each door on my Civic. I will be running two Crescendo PWX6.5's per door as well as one PWX8 per door. All are single 4 ohm. That gives me either 2.67 ohms or 6 ohms to each amp. The amps will do 220x2 @ 4 or 240x2@2 or 680x1@4 bridged. What would be my best option for wiring? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
graham0599 Posted October 10, 2014 Report Share Posted October 10, 2014 I'd probably do one 8 on each channel of one amp. Then 2 6.5's on each channel of the other amp. or all 3 wired to 2.67ohm bridged. 1 per door, set with 0db tone. But that's pushing it since it's stable at 4ohm My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
mothra Posted October 10, 2014 Report Share Posted October 10, 2014 8s on 1 amp, L&R. than 6.5s on the other amp, L&R. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 10, 2014 Report Share Posted October 10, 2014 My experiance is PA dont need much at all to get loud. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
timc31610 Posted October 10, 2014 Author Report Share Posted October 10, 2014 Thanks for the responses guys! Once I get everything in the car I may try several ways and see what sounds best. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
