Need help picking my new amps for my 18 subs
loosewire
  • 2 months later...
what brand of subs are they and resistance and voice coil arrangement (ie: what load you will run the amp at) and RMS rating for each sub. This allows you to see the optimal running power for your amp/s, as depending on RMS rating you may need to strap 2 amps together to give you sufficient power for your needs. then you should do the big 3 (if you haven't already) and possibly upgrade your alternator (If stock).
so in essence - what is the combined RMS rating for your two subs together (To give you total power required RMS) and make sure the amp is rated for around your total RMS value and resistance level (ohms) with these two figures you can look at amps and their RMS power output at your resistance level - matching the power of your amp/s to your subs!
Happy shoping
so buying amp for new sub......is this like whenever you buy a new sub you buy a new amp??
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
  • Who's Online   0 Members, 0 Anonymous, 763 Guests (See full list)
