damn headlight dimming
Do they dim when the engine is idling or when your driving and the rpm is higher, like 1700?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
pretty much any change in voltage is going to cause headlight dimming,
I'm going to get a regulated DC to DC power supply to run my headlights. Most of them take 8 to 18v in and give you a 12v out. Finding one that can do it at 15 amps is the trick. So i am still looking
To reiterate what duck just said, you will notice dimming with the slightest of voltage drop, even 0.1v. If that annoys you convert to hid headlights, DC ->DC power supply (to keep the voltage going to the headlights the same) or who knows what other options are out there now.
I chose HIDs and changed all my interior lighting to LEDs.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
if you switvch to HID the dimming should stop sincd there are caps in the ballast.
if at any time you are pulling more current than your alt can produce, your lights will dim. sounds like you are clipping and drawing a lot of current.
but if your voltage is dropping for any reason your lights will dim/
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
You can get a second AGM to hold the voltage higher decreasing the drop. Not really necessary for that setup but if you're looking to get rid of the dimming, ditch the cap and get another AGM to wire the amp to in the back
.1v of drop and your headlights will dim.
get LED headlights or HID's. only way to stop dimming.
I didnt know that hehehhe I teh nub I'll get HIDs
Kenwood KVT-614
(4) Marathon 155 AH batts
2/0 OFC SHCA
Mechman 370
(2) Audioque 3500.1
(2) AA Mayhem 15s
  • Who's Online   0 Members, 0 Anonymous, 3191 Guests (See full list)
