Meter testing whats going on?
temperature and humidity can change a lot, as can seat and visor positions
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I'm thinking it's a combo of the cabin and might be tuned lower than you think.
Just a guess tho
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
R you limited in power for your class or something? Add more power and that bish will get loud.
Only power I'm limited to is my check book. I have a second T2000 going in a few weeks. For meca I will be in Radical X cause my amps will be infront of the b pillar
We will put out through the IM-SG this weekend if you'd like :)
It's a good number and it feels great inside the truck. I think it will really wake up when the second amp goes in and both are running at 1 ohm. I still think they may be begging for more power ;)
Lets get'er done
Nice. Remember, seal it up, and dont move or touch anything. It is VERY VERY sensitve. Read the directions, and you see exactly what that bitch is doing.
I think you may just be surprised. ;)
Sealing is gonna be fun. I havent sealed the blowthrough. you can feel air moving into the bed.
Also sweeps dont tell the whole story. They give you a ball park. Then you go through individual tones and see. Using the spectrum analyzer you can kinda see if you should go up a freq or not, but I usually do a +-5hz anyway.
Also temp of the equipment is a factor, once youve got 15 burps or w.e on em from cold ive seen a couple tenths here or there ..
Spl is a finicky bitch. Check your box to make sure ot hasnt shifted or the port come loose especially if an aero port when most ppl tape em during testing.
I will say, you should use the same level tones throughout. Dont switch from a 30hz -5db to a 30hz -10db bc obviously theres gonna be a difference there.
If your testing spl EVERYTHING ELSE, has to remain the exact same. If not, the data in this case spl, is inconclusive. Which is bad.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Well the IM-SG has the bix tuned at 31 and I if I remeber correctly it peaked at 30 and 43. Didn't write anything down cause it was the first time playing with the IM-SG
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
