Creative installers come inside
Speaker wire out from amp to a relay at the dash. You can have the signal come in, then 3 or 4 or however many switched outputs to the enclosures. There is the danger of accidentally turning on more than one at a time. This is where Tony's expertise comes in.
SMD Super Seller
My Feedback Thread
Could tell him to get a ohm load that allows him to run his amps right
Misunderstood it Nate. Its ment to swap woofers on the fly.
Example... Listen to this JL w3 8... Now listen to this dd redline 500 series 10. Now listen to this illusion carbon series 12.
That's what he does on demos to sell people stuff, and he wanted a better way to do it besides getting out and swapping wires.
Wouldn't you need different amps for each set up if they are different RMS? I would imagine you can just have various remote wires that run through switches that can turn on and turn off amps as needed.
You misunderstood too. There is a single JL 5 channel on multiple sub set ups. This is a sales tactic to hear the different subs on the same power in the same vehicle.
Example. Guy walks in, and wants to hear how the JL preloaded dual 8's sound vs say a preloaded DD redline 12 since they are in a similar price range. Ect ect ect.
Put switches on the speaker wire? Have the subs all hooked into seperate speaker cable, run through a switch and then into the amp?
if he dosnt mind it looking kind of ghetto and just wants it for work then go to radio shack and pick up the speaker selector its simple it has a main left and right input then 4 selectable outputs
http://www.radioshack.com/search/index.jsp?kwCatId=13384949&kw=speaker%20selector&origkw=speaker+selector&sr=1
Build Log
1996 chevy suburban
2 zv4 15
kenwood excelon mids and tweeters
kenwood excelon deck
mevhman 370
3 batts all different
mechman avmb II
2 inch squat
33 inch muds
straight pipes
kixker zx series 4ch
sundown amps
memphis 0 gauge
soon to be fu audio c pillar wall
  • Who's Online   0 Members, 0 Anonymous, 5208 Guests (See full list)
