Electrical for 5k opinions?
Hey guys im just a few weeks out from my build being completed and I currently think im pretty set with the electrical i hope for 2 new style kicker kx2400.1s and a ix500.4 and a 75.2. Roughly 5k rms and 450 amp current draw or so. Currently i have sitting a new xs chrome 150 amp alt.(not installed) (build is for an 81 elco) I do have installed Both under the hood a xs d3400 and a d1200.(small 3.1l motor plenty of room) I also have sitting and think i may throw in the small size cab is a xs xp750 and my real question here is with that what ive listed in mind how am i sitting for someone who enjoys daily pounding at full tilt for 10 plus minutes. Inside the cabin i am fitting the amps and a already build fiber glass encloure box. I am having built a custom center console(where i think the xp750 will be and a xs vcm module. Would you guys add anything else like a capcell or even a 10 farad cap? i know most times the cap answer is no but thats usually people asking who already dont have any batteries in line which im kinda average i think for what im asking for. Any suggestions here would be great thanks!
225 Excessive Amperage Alt.
4 Yellow top batteries
Pioneer AVH-6600
Kicker KQ5
2 FI 18 BTL's fully loaded
2 zx 2500.1's
4 ks6.5 coaxials
4 ks5.25 coaxials
kx650.4
http://www.cardomain.com/ride/2358078
For that power, I'd consider at least 2-3 good group 31 batteries in the back, like an XS D3100. Don't bother with caps unless you're talking Maxwell caps.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Really cause according to the xs power chart I'm ok and of the batteries I'm already running the 1200 and 3400 stack up on paper like a single d3100 so according to u I need like 3 d3100s for 5k? I'd think that's closer for a 7.5k+ range
Pioneer AVH-6600
Kicker KQ5
2 zx 2500.1's
4 ks6.5 coaxials
4 ks5.25 coaxials
kx650.4
You usually want 1 group 31 per 2k of power. If it was me, id go with 3 3100's, and your 3400 upfront.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
I'll be running close to 4k with a 250amp singer alt, 2 runs of 0 gauge and hopefully fit a group 31 under the hood. If voltage drop is below 13v ill add either a second battery to the back or a 1k farad or bigger cap bank using Maxwell caps.
As an idea of what it takes for that power range.
You said you have a
150 amp alt
Xs 1200
Xs 3400
What about wiring? Cca/ofc? Size? Amperage rating? Big 3?
My opinion
Install the alt and batteries with half the power going to your subs. If staying above 13v full tilt add the other sub amp. If dropping below 12v add another battery or 2 untill voltage is above 13v for at least a few songs.
A bigger alt would be better with such a small alt you need more batteries.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
XS's chart doesn't count on you playing it for 10 minutes straight. SImilar to what was said above I would just go in assuming you'll have to try it and see. Get it all in there and just play it to the voltage you're seeing. As a general rule if it starts slowly dropping into the 11's you need more batteries, but if when you turn it up it immediately drops into the 11's on charged batteries you need more grounds.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
With that lil alt i woulld do d3400 up front and 4 d3100s in back
I would do minimum 2 runs 1/0 ofc to back and big 4 1/0 ofc. With good solid frame grounds
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
wow. Alot lot of information here that conflicts what im planning. Guess I will have to start another thread.
Still learning but have started gathering.
biggest alt you can fit under the hood.
two group 31's in the back.
see what your voltage drop is.
if its bad, add another battery.
throw the car on a battery charger once a week or so to top off the batteries.
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
