I run 8-ohm. I guess less than double the power equates to more loud now. Have fun with your output impedance, your lack of cone control, added risk, voided warranty, less life time of equipment, dirtier signal, larger costs, and most importantly no gain in loudness.
But hey, power increased... :shrug:
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
2ohms
Because why go lower when I can get the same at a higher impedance?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Sorry to hear that.
ok well ived been talked out of .5 ohm by a friend gunna throw my level 4 12 in there wich is also dual 2 ohm and run at 1.3 is what we figured i dont think there will be an issue with that on the sundown with my current electrical 3 dual 2 ohm subs wired to 1.3
.. So now your going to mix match...
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Come on man. you've got to be trolling.
