What is a good 12inch shallow mount sub?I'm not to familiar with shallow mount subs I'm wanting 600 watts RMS
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
how deep is the box
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
And what ohm load are you looking for (assuming you already have the 600w amp)?
Static drops are my bag.
I just got an 04 super duty crew cab and wanted to put 3 or 4 of then in the back between the rear seats and wall .. I have a Memphis MOJO 2500 amp to power them looking to be at 2 ohms final load ..
SD12 from sundown...but I doubt you can fit them behind the seat..probably stuck with sd8's or 10's. But if its going to be sealed I wouldn't write off the 10's. I installed just one sealed in my bros civic on about 300wrms and it sounded so nice.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
the sd-2 10 will get down had 2 in my old dakota sealed
2 sundown sd-2 d4
flex tech
box design by Joe X
What does said amp do at 2ohms?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
