Bracing with angle iron (thick...not the flimsy stuff)
magillaru
Its a pain in the ass always adjusting the fence on the saw when cutting but the outcome is so much stronger.
Everything I did on this box was interlocking corners, all joints where also offset on all layers so there wouldnt be 2 pieces of wood ajoining in the same spot.
http://www.stevemeadedesigns.com/board/topic/146201-dodge-charger-10000watts-rms-to-a-pair-of-fi-btl-n3s/
Can also check out how I braced the sides on this 4 18 box. the thing is a tank, but the added bracing took minimal displacement away compared to doing a full added layer.
http://www.stevemeadedesigns.com/board/topic/174700-yukon-xl-rockford-fosgate-atomic-sundown-xs-power-sky-high-alpine-digital-designs/?hl=%20yukon
Simple U shaped panels between the port wall and outer edges can be done as well like so.
Here are some other ideas..
10304631_785000871534230_566996569831503
10468081_785254031508914_172642069270814
46702_728094560558195_1552423215_n.jpg?o
10003910_728152433885741_1538024448_n.jp
I take it those are your designs?.....unreal woodworking skills....very nice!
I decided I'm going to shave off 3/4" from each front baffle (port sides) with the jig saw and make new ports with the inner port layer extending to the front edge of the baffle (excluding the beauty panel). This will keep the port more consistent as well.
I'll post some pictures tomorrow of the results.....wish I didn't have to work tomorrow!
Again, really nice designs! Quit showing off! haha
Singer Alternators
Team Asshole
#anothershittysingerbuild
yes sir, and thanks!
Just some of the boxes I built, trying to show ya examples of ways to stiffen things up, and a couple ways to brace without taking up a crap ton of displacement throwing the box specs all to hell and back. ;)
They make a pill for that you know...
:drinks:
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
God your woodworking skills make me want throw my tools in the garbage and just pay you to do my enclosure builds. Do you ship or do I have to drive to Wisconsin ?
Dont need angle iron in such a small box..
A lot of strength could of been added with interlocking your joints, but you didnt do that.
Changed the baffle to give it an interlocking joint......had to use a jig saw with an extended blade....big mistake. Cut came out horrible but I was able to sand it down a little and with bracing and tiger hair, it should be okay.
I was very tempted to cut out the entire baffle and redo it but was worried about damaging the other surfaces and making it worse.
(port walls are only propped up in this picture, not glued yet)
*you can see on the right side, the surface got chewed up a little bit....good thing I'm putting a beauty panel on here!
3FD64306-E249-4D5B-A191-4BC7159C5BAB_zps
*Definitely investing in a decent table saw.....OR, sounds like a good Christmas present the wife can get me! haha
Singer Alternators
Team Asshole
Already done! haha
That seam on the left isn't nearly as bad as it looks in this picture.
I was really pissed at first but it didn't turn out as bad as I originally thought.
Singer Alternators
Team Asshole
Do you think it would be worth the time/effort putting corners in like this for the front baffle? (I would also have a piece running along the edge connected to these wedges).
6A57DE96-359A-409A-A212-2F90B9692DF7_zps
Here's what I'm thinking......
0EFEAA6B-1D7E-496B-BB0D-6BFFE969DD3C_zps
Singer Alternators
Team Asshole
  • Who's Online   2 Members, 0 Anonymous, 4563 Guests (See full list)
