2 amps, 1 woofer
MatthewBigBossWilliams
Why buy things that you don't know how to use? Do you even have a sub that can take 1500w per voice coil? If you do, it's pretty ignorant to purchase items that you don't even know how to install. You should have done that research first before buying two amps. Do you have the electrical to support 3000w?
I bought this because it was suggested to me, And yes I have everything that I need. don't worry about my set up, I just asked a question.
used an outside company as a consultant in the research on this matter, i can send you the invoice on the labor if you'd like...
http://www.stevemeadedesigns.com/board/topic/76428-2-amps-to-one-sub/
I looked through the post and it still seems like it is the same thing that I know of. I just don't know what wires and such I need. and how it would go through both amps.
Those amps arent strappable I don't believe from looking at the pictures/specs on crescendos site. So you need power and ground to each. RCA's from HU to one amp, another set from first amp to second amp, and then wire each VC to one amp
few things we are going to need to know before we give you further information
1) type of sub
2) voice coil configuration
3) electrical system overview
4) type of system enclosure ( burp box vs musical daily box)
Thanks,
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
Also going to have to worry about gain matching the two amps, cause if they put out even slightly different power levels you're going to run into issues quickly.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
1) type of sub
Thanks,
:ninja:
1) FI SP4 15 dual 1ohm
2) ^
3) Stock alt with stock battery in the front and 2 Kitetik KHC 2000 in the rear
4) Musical daily box
  • Who's Online   1 Member, 0 Anonymous, 2254 Guests (See full list)
