madnking Posted November 11, 2014 Author Report Posted November 11, 2014 After displacement of port and subs im at 8.5 per cube for port area so I guess ill redo the face with another port or make a slot port thanks
madnking Posted November 11, 2014 Author Report Posted November 11, 2014 I have 3.5 ohm box rise clamped amp at approximately 3500 watts
Kyblack76 Posted November 11, 2014 Report Posted November 11, 2014 two 18's.. and wha? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Bass head 4-15s Posted November 12, 2014 Report Posted November 12, 2014 Dud i have two SQ hdc3 18s i run 3-8 inche ports on 12.3 cube net and its loud on 3000 watts you need at least that much or more that's 150inches of port.
MrSkippyJ Posted November 12, 2014 Report Posted November 12, 2014 Good luck man, it's good to see someone ask for advice and actually listen, if you do in fact listen! Read what these people are telling you and apply it! We are a very helpful crowd if you give us a chance! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
SlamminBeats Posted November 12, 2014 Report Posted November 12, 2014 the options below are what i would do to gain. it may be the ports but honestly I see the problem being the entire box orientation. Also with aeros you generally don't need as much port area. 1) turn box over so port up/subs up (if possible) 2) turn box around so it loads off hatch (not really ideal imo) 3)or keep it the way it is and seal off
n8ball2013 Posted January 27, 2015 Report Posted January 27, 2015 How many cubes is your port still looks pretty small. I know my wall has way more port area than that and it's similar size. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
n8ball2013 Posted January 27, 2015 Report Posted January 27, 2015 You really should stop building until you fully understand what you need to do to designs properly. You're just blowing money right now THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
