4 gauge for 240 amp alt for now?
So I just got a SAZ-1200d and to go along with it (although possibly not needed) i was going to get a high output alternator to keep it going strong even at idle. Now i was going to go ahead and probably get the 240 amp alt from mechman. I know this is obviously more than needed for this amp but in a hobby drivin by upgrades i figure it will give me some room to expand. Now the question is, as of right now my big three is in 4 gauge sky high, is it okay to use a smaller amp fuse than what the alt is rated for (until i get a bigger amp later) since the 1200d only draws ~120 amps?
Thanks in advance!
Greg
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
Where are you going to put the fuse exactly?
And a smaller fuse is always ok, from a safety standpoint. Going bigger is when you have problems. The fuse is supposed to be the weak link.
And is your wire off or cca?
4 ga ofc is rated for 150 amps I think.
Just don't install a fuse rated higher than the wire you have.
What kind of vehicle is this in? What size stock alt? You having dimming issues that are making you do the upgrade?
I would just do it in OFC 1/0 because if u later upgrade u will need to upgrade to 1/0 ofc anyways. Why buy wire twice. Easier to do it once and call it a day.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Reading> you. He said he already did the big three in 4 Guage so he would be buying wire twice.
Sorry read wrong
Fuse was going between alt and battery. And it is OFC. And I got some 150 amp fuses so that would be perfect for the 4ga.
stock alt 105a
It is a 98 blazer with a 105 amp stock alt. Reason for upgrade is I was driving the other day in the dark with my lights on and my air turned on high (the fan for the A/C or heat) and all of a sudden I had a huge voltage drop from normal 14ish to about 13. It had never done this before so I took it to a buddy to check the alt ( and we checked all connections just in case) and apparently something inside went wrong because under full load now I was only getting ~60 amps or so.
stock alt 105a
You're absolutely right. I should have went ahead and did big three in 0. At the time I bought the 4 gauge I thought it will be enough I'm not gonna want to upgrade....that was stupid to think haha of course I'm going to want to upgrade.
stock alt 105a
  • Who's Online   0 Members, 0 Anonymous, 1954 Guests (See full list)
