Will this be good enough?
dont really understand why voltage drop would be much different at cig lighter and amplifier, it may be a lil different due to the length of wire droppin some voltage but electricity travels very fast u say ur not pullin 250 amps out of ur cig lighter? ur pullin 250 amps out ur ELECTRICAL SYSTEM, which ur amp and cig lighter are hooked to.
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
At the amp voltage can and will vary more. The length of wire has more resistance and the demand is higher at the amp then at the cig lighter.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
If you use the cigarette lighter it will show you the electrical system voltage for sure. If you are playing full tilt and drop voltage your cigarette lighter will show that.
But what if something happens to the amp or batteries and your amps are only getting 11 volts but the cigarette lighter is still getting 14? If you want to run at 1/2 the recommended impedance you better know what's going on at your amps, not the cigarette lighter.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
in what situation would the ciggarette lighter be getting 14 and amps be getting 11? just curious i will be using a volt meter for the first time ever in my build next year
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
It could be a simple as a loose connection at the amp. It's not an entirely likely situation for sure but I would rather monitor the voltage as close to my amps as possible than monitor the overall voltage of my electrical.
F150:
Stock :(
Processor: DSR1
Could be a blown fuse as well.
I know in my car with stock electrical and 0guahe front to back the voltage upfront was dropping down to 12-12.3v. However at the amp it was 11.4-12v.
That was with a 1500.1bdcp and 0guage front to back. Voltage at both points without draw would be the same. Crank it up though and it was different.
Just the WA it works sometimes.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
The irony is if you can't afford a second amp to run each at safe impedance you certainly can't afford to repair or replace your amp when you blow it up. All the battery alternator and cable in the world won't make .5 ohm any less stressful on equipment. if it were designed to run at .5 the manufacturer would publish that and warranty it.
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
