Enclosure for 2x HDS312's. Look good?
JMac91
Oops.. cut off a little in the screen shot.. Height is 15 x 36 Wide x 24 Deep, Top and Bottom cuts 24 x 36..
Does this look good for a dual HDS312's box? I tried to get the tuning under 35 intentionally but didnt want to sacrafice too much port area. Got a good net area for these subs tho. Also wanted to add a V in the center of the back wall to somewhat guide air to the port coming from both chambers. Im not sure what I should add in displacement or how much displacement it would cause, it wouldnt be too big of a piece.
Vehicle: 2002 Volvo S60 2.4t awd.
Headunit: Kenwood DDX-470
Doors: 4x Focal 6.5s/tweets (Adding)
Sub: 2x Sundown Zv4 12's D1
Amps: B2 Zero.1, MB Quart OA600.4
Box: 5.2ish @ 32, Made with Maple, solid oak braces, 45s all around, 2x 5.8" pipes, all fiberglassed up.
Battery: XS D3100, Block Shakers 110AH
Alternator: 250A Excessive Amperage.
All Sky High OFC Wiring.
My Build, plenty of pics: http://www.stevemeadedesigns.com/board/topic/198281-2002-volvo-s60-awd-24t-build-log/
Needs more port and less net volume. What power are you running for your amp?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
AQ 2200D, I think my alt is lower 100's. HC2400 Battery.
Any other opinions? im going from an AA Mayhem 18 to these little 12s, I loved the mayhem.
Tune a little higher, more port.
I actually think the box is a bit on the small side, I would be happy with 5-5.5 with that power
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
aww more port.. ok but I wanted to tune it a little lower than the standard 35-37.
you dont need to
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you dont need to
Thanks, looks good as is then? Is there anything I should be concerned about, box related.
For your reference, with your space I would do it as follows keeping your stated tuning, subs to rated power:
Same subs, same power. Damn near same box.
My specs, 15" h x 36" w x 22" deep. 18" port, 4.25" wide. Tuned to 35hz iirc.
I have a port plug in now that lets me play down to do 25hz @ 142
This is the bandwitdh you'll have with that box. Might vary a bit if you don't have a stratass/sebring. (without the port plug and 7/8 full tilt)
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
  • Who's Online   1 Member, 0 Anonymous, 5432 Guests (See full list)
