Is it good or bad or crimp wires then solder?
was kinda waitin for Snowdrifter to jump on this! not to thread jack, but is there a better way...crimp or solder? as long as its done correctly, I would think either or.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
crimped if using a heavy duty crimper (12-16 tons) is a better connection. it can apply so much force that it cold welds the metals together. now the catch is that you need to use similar metels ie( copper wire and copper lugs) so they bond correctly. im not sure if CCA bonds as well with a crimp to a copper lug as pure OFC.
a good solder job isnt bad either but you need a quality solder. for anything important i use silver solder. contains 6% silver, this solder is very expensive (80 per roll) but it is the best you can get. but once you start paying for that you might as well invest 50 in a 16 ton crimper from ebay and call it a day. doing both is kinda overkill. if you do it either way you need good lugs and proper tools.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
looks like a heavy duty crimper is in my future! thanks guys!
Singer 220 amp alt
Who needs a crimper I use a pair of pliers and squeeze them with a clamp.
:peepwall:
Crimping is the most reliable connection for a car, but a good crimp, hammer crimp doesn't do anything at all. Worst connection ever, if you can even speak about a connection.
Hydraulic crimping is the best and easiest way.
Well, I did crimp 0/1 last night with a chisel, a mini sledge, and my vice.... And I can tell you that when I put it in my vice, I can pull on it as hard as I want and can't separate it.
1. I hope this is a joke
2. Just because you can't separate it doesn't mean it's a proper crimp.
The split style are kinda weak and the crimp doesn't stay as well as I like. That's why I solder them..
I have tried rosin core solder with CCA wire and copper lugs and it didn't work for me but I have no issue with IFC wire.
Just my .02
This is a proper crimp, 1/0 with a copper lug crimped using a 12 ton hydraulic crimper.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
