bad Subwoofer Unloading Issue
bassaddiction
only does/did this, when you doubled the power?
shrink the volume.....
its only happening to one sub tho. u think it could be the box size ?
im asking you
did it ONLY start when you added power?
sure.. swap em.... and report back....
while out, look at the spiders, glue joints and shit.. and i mean LOOK at them.
2 12 inch hdc3 yes its a 8 inch port
im going to try switching the two subs
thanks gckless
add these sub can handle way more then 4k there still cold after a half hour
lol
ok.... lol...
that is what i was thinking....
u could be right. but i seen alot of poeple run this much power on this set up
any way if i rip the spider ill sell the basket and get better shit
thanks gckless
lol
ok.... lol...
well. lets just get to it
what power are you running?
Ill bet your not close to 4k....... no offence.
im asking you
there is one part of the spider at is a little lose i mean a little but its always been like that
i checked it when i put the baffle in. it was the same
thanks gckless
lol
ok.... lol...
2 aq 2200 strapped 1 ohm
i only let it drop to low 12s so i never really full tilt that shit
at .5, and staying around 12, i stand corrected.. thats good amount of power
swap subs..
and when the other one does it.... shrink your vol..
or if the same one (when swapped) does it.. recone.
1 ohm so ya .5 each amp but like a said i dont let it go below 12
ya they can take it lol fucking things are 60 lb each 3 inch voice coil and u cant even push them down
i did fold a cone back when i had only one sub on 2200
  • Who's Online   2 Members, 0 Anonymous, 1852 Guests (See full list)
