This is starting to drive me crazy
You might try lowering bands of the EQ rather than raising some. Also avoid the use of the "loud" function, this could be part of the cause.
I don't use the loud feature, It was a test to see if it changed the way it sounded, Lowering eq? I like the Vocals & instruments as Accurate & clear sounding as possible, wouldnt this reduce all of that? Or are you saying Bring them all the way to the bottom & copy the same curve as if I was starting at a flat setting?
I just ordered New Rockford Rca for same day delivery tomorrow, From my understanding low quality Rca's are more likely to pick up engine noise etc...I don't pick up any engine noise with my current rca's. Would this be a waste of money?
Start with your EQ at 0, then reduce what you don't like rather than raising what you do like.
Since the problem increases with volume, it's likely the problem is something in the H/U.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
attach ground wire from HU to Amp, see if any change.
Loop RCA's and power/ground wires through a ferrite core bead (choke). Each should have its own, loop at least once. You can test each individually with a single choke instead of having to buy 4 or 5 of them for testing.
If it doesnt help, its a noisy head unit or amp..
Hammerdown... 1%
Did you bypass the amp and run the speakers off the hu to see if the hiss is there?
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
I've tried looping the rca's, Tried grounding straight to the amp ground, battery. I have not tried running the speakers from H/U power, That won't give out enough rms to my speakers, I have however tried different amps, Same problem.
Unfortunately I use all the bluetooth/Navi functions on the H/U, So Replacing the H/U with a newer one with the Same options is out of the question $600+
does it do it when you play CD's or wire direct? my brother likes to use the Bluetooth with his phone to listen to music and brings his quality to shit.. if you havent tried cd or quality music on ipod or phone not using bluetooth a recommend you try it first
It does it with cd & sd/usb just barely, Am/Fm it doesnt do it at all. Bluetooth music just barely, Bluetooth phone calls is morre prominent than the rest. Think it would be an issue with cheap rca's? I'm using some Rca wwires I had from last year (Bought at autozone... :unknw: ) They don't induce any alternator whine though
Try and bypass the EQ, try a different H/U, run some new wire to one side and see if you get the hiss.
Trouble shooting is a process of elimination and requires you to go through your system one piece at a time to find and isolate the cause of the problem.
Never assume anything!!!! You'll only overlook the one thing that might be causing it.
Try any and all combinations and you'll find the source of your problem.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
