Quality In Box Terminal Cups?
Genesis730
I simply drill through the box and feed the wire through it and seal the wire in place.
I do not use exposed bolts or threaded rod as it is poses a risk of shorting out and causing a fire.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I have used terminal cups on with 8" speaker boxes for yrs.
For running 8g to my SP4's I used 1 of these distribution blocks per VC so the wiring could be changed easily if I wanted
$(KGrHqNHJBMFHbKuL)MOBR9z-7G8SQ~~60_12.J
I only consider them good up to 600 watts per ohm..
The limiting factor with any of this stuff is how many amps of current they can handle. For those terminal cups I wouldn't put more than 25 amps through them. 25 amps at 1 ohm is 625 watts, at 2 ohms it's 1250 watts, and at 4 ohms it's 2500 watts. Hence, to be little on the safe (and easier math) side, I say 600 watts per ohm.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 4682 Guests (See full list)
