Sound Deadener in the Doors
Joseph Chambers
When I did my doors I did 100% only because I had huge gaps in the door that I wanted to cover up. I wish I did a second layer but I didn't have enough deadener.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
OP...check out a site called www.sounddampenershowdown the dude breaks it down fairly well showing what closed cell foam, mass loaded vinyl and cld tiles are and when and where to
apply what.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
i covered the inner and outer shell with q-mat and bolted 1/8th inch steel to cover any factory holes then applied more dampening over all that. Word of advice do it overkill the first time and never worry about it again.
Also watch out for people slamming the door on your truck because those doors will be considerably heavier, but you will get that satisfying thud when you close it.
I'M SO EXCITED! :)
Just received: stinger 2150 5000w battery. Installed.
x2 soundqubed HDC3.110 D1
x1 audiopipe apcl-30001d
10421175_10204689303125122_8385184121582
10898121_10204689303165123_5004603173514]
10891708_10204689302765113_6199557598404
10689489_10204689303085121_4588993554035
HU: Pioneer DMH-Z5350BT
Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way
Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1
Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable
Sound Deadener: 121 sq feet of Skyhigh 120mil
DSP: AudioControl DM 810
Project Build Log
Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress.
  • Who's Online   0 Members, 0 Anonymous, 1883 Guests (See full list)
