Sound Deadener in the Doors
Joseph Chambers
I have a question: When I'm applying sound deadener in the doors - should I just place 2 sheets in different positions in the door or do I cover the entire interior of the door? i.e. overkill?
HU: Pioneer DMH-Z5350BT
Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way
Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1
Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable
Sound Deadener: 121 sq feet of Skyhigh 120mil
DSP: AudioControl DM 810
Project Build Log
Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress.
If you have a properly designed real CLD... 25% coverage is about all you need. But it doesn't hurt anything to do 100% coverage. If it's not a true CLD then you need all the help you can get. Go ape shit.
Most SQ vehicles that compete on a regular basis have 100% coverage and then some ... Including mine.
Just saying ...
My 49 Ford project will be double layered then moving on to the MLV.
... If I can ever get back to working on it ...
I'll be 100% covered, plus closes cell foam in the front doors and behind all the trim pieces.
Deadener is to reduce panel vibration. Which is great. But you can still have air Bourne noises and trim/panels rattling against each other. Which is where ccf comes in. The foam acts as a barrier for air born noise and helps prevent those trim/panels from rattling up against other stuff.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
25% is a good starting point. After that your mileage may vary. You run into diminishing returns. If you go 100% it can't hurt, but if you do 25% you can cut the sheets up and place in the middle of large flat areas.
1997 Lexus ES300
HU - Pioneer MVH 7350
Processor - Helix DSP
Front Stage - JBL P660C
Mid/high amp - Alpine PDX-F4
Subs - 1 IA Death Penalty 12
Sub Amp - Cactus Sounds PF300.1
If you're going for luxury quiet you will need mlv and ccf applied to the door. Also seal up holes in the door as best you can. Use a couple layers of flashing or some thin metal that's pliable. Deaden that as well.
1997 Lexus ES300
I put as much deadener as i could the first time around,didn't want to have to mess with it again. i put it on everything that was metal that i could reach. no such thing as overkill imo.
Thanks for all your advice today. I think I will start at 25% because this shit is expensive! haha. Today it goes in. One question though: I have a buddy who says the truck bed liner in the floorboard also helps and that I can use that on the floorboard of the truck. Is that true?
whats mlv and ccf? My buddy whom I mentioned above will be doing my interior all leather. Here in mexico I can get a full hide for $120 and its a lot thicker than in the states. :)
Project Build Log
I did much damplifer on outer skin.with a layer of closed cell foam.I did 100% coverage of damplifer on inner skin covering everything .I also added some damplifer to plastic door panels with some closed cell foam.
If wait tell holidays second skin has good sales. That's what I did
  • Who's Online   1 Member, 0 Anonymous, 1936 Guests (See full list)
