I have build up around the battery terminals and need to clean them... I just got a sound system in stalled over the summer and needing to know which terminal do I take off first ? Because my amps are connected to the battery and I just want to make sure I dont blow a fuse .....
Buildup as in the white/green stuff? I usually get water to just below boiling on the stove, scoop some in a coffee mug, and pour it right on the terminal in question. Gets rid of that crap in no time.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
mix some baking soda with water and pour it on the terminal
after its clean coat everything in dielectric grease to prevent that problem from happening again.
but wont the water cause a spark from the battery ?
NO
JBL
X2
This works wonderfully
Since noone answered it, you have to remove the - first, then the positive terminal. (remove them both while cleaning.)
To put it back on, you first put on the positive terminal and then put on the negative terminal.
Use coke as in coca cola
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
they make battery terminal cleaning tools. they work real well. cola is ok, if you want everything to be sticky and the paint on the subframe below the battery to be eaten away.
Cables and wires almost never fail; the terminations do.
I'm now thinking the best solution will be hot water with baking soda in it. No point in scraping away at it when the solution will do 90% of the work.
My feedback thread
