Yes I am using Photobucket, when I post the image via the "Image" button and hit okay it doesn't respond. Acts like I hit nothing at all
just copy the image link from photobucket and paste in the reply box instead of using the image option...
Money Baby! Here's the truck!
And here are the previous subs!
4 skarbage IVX-10's on my AQ2200 (subs are inverted for wiring) They were on double rms and not liking it that much at all. They were also on loan from a project from my dad as a temp system while we were getting this build togeter
Team Lethal Pressure Vice-President
2002 Ford F-150 Supercrew
-Taramps DSP 3000 (subs)
-Taramps DSP 1600 (mids)
-8 Skar Audio FSX Mids
-4 Skar Audio VX35-ST Super Tweets
-85' of 1/0 EB Flex Welding Cable
-XS D3400 under the hood
-Datasafe 12HX505-FR in the rear (110 ah)
-Pioneer AVH-2700BS
-2 Soundqubed HDS315's
-4th order Blowthrough
-100 Sq. feet of deadener (Qmat, GP STFU, Noico)
-147.8 @ 40 Hz
-Top 5 in 904 SPL Outlaw's Walled List
-Rebuild on the way
Had my old cheap RCA's break off inside my input so I had to take apart the input to get it out and then the other input slid back so I had to push it back up through the tube and solder it back (never heard of anything like that happenning) quite odd honestly
2 channel and the SHCA wire going in. This is back during finals week when all my equipment was coming in.
Mmmmmm dat @$$ first serious subs I've ever own and first 15's I've ever owned. Super excited. I'm Impressed with these subs as a whole, thick thick magnet, outstanding ventilation and I love the basket design as well as how high the roll on the surround is. Definitely not bad for $150 a piece (Black Friday Sale)
-Pioneer AVH-2700BS
-147.8 @ 40 Hz
-Rebuild on the way
Box Day!!! (Day 1) Lmao
All the pieces Cut
The Only scraps from 3 sheets of 3/4" Birch! Not Bad B)
Shell, With 45'd Corners and Middle Bracing
Sanding Down the Port/ Port Baffle
Removable Port FTW
Port Test Fit
Little Bit of a Jump Here... Inverted Double Baffle, sunk in for the subs, Put a dowel in each sealed chamber and started Priming and Sanding
Ze Accordian Boot :ph34r:
-Pioneer AVH-2700BS
-147.8 @ 40 Hz
-Rebuild on the way
God that's HAWTTTT Money Shot Baybayyy :wub:
View Through the Port
Test Fit in the Bed, just trying to get an idea of where the cut will sit within the cab and where we need to bolt this bish down.
Priming the Port
Sanding Down The Bed and prepping with acetone for the Herculiner
Bed Liner ON! Drying with a fan in the garage because it was midnight and raining. Had to put on another coat after that and get cleaned up to be up at 5 for work :cray:
Had Some Extra Bed Liner in my paint pan so I rolled two coats on the bottom of the box
-Pioneer AVH-2700BS
-147.8 @ 40 Hz
-Rebuild on the way
Dang, I start posting stuff and Everyone stops posting. Anyways, more to come soon, I'm getting off so I can get up early to keep working on this build. Posting Pics of the interior tomorrow and the glassed door panels as well as deadener, new carpet. Ostrich Skin Leather Seats are going in tomorrow as well too :D Thanks for the interest guys! I'll keep it coming! Tell me what y'all think and If there's anything you would have done different Or liked how I did ! Lots more to come!!!
-Pioneer AVH-2700BS
-147.8 @ 40 Hz
-Rebuild on the way
Got a bed cover ???
Got a bed cover ???
Yes I do it's a little cheap soft tonneau cover we had to mod and cut and stretch to fit... I'm still looking for a fiberglAss one
-Pioneer AVH-2700BS
-147.8 @ 40 Hz
-Rebuild on the way
