hdc3 true power handling
akaak
i wouldnt wire amps to .25 thats asking for trouble. 2 larger amps at a higher impedence will yeild more power at a greater efficiency. if you are limited on money. electrical is usually the most cost to upgrade. i would swap for the subs first to wire at .5 each, then upgrade amps and electrical as necessary
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Ya I mean I make plenty of power enough right now. No reason to push my amps so hard to the point where they're very inneficient. I'm just going to upgrade my mids and highs and then build a wall later with 4 15s.
There is no such thing as impedance RISE.
Period.
explain your point of view please.
BMW M340 xDrive
It's not my point of view, ask any engineer about impedance RISE, he won't know what you are talking about.
Impedance is just resistance + reactance.
Reactance is dependant on frequency.
If you plot the impedance: impedance in function of frequency, you will see there will be 2 peaks.
It's called the impedance response.
Did you read anything I posted? I clearly stated inductive reactance. The common word for this at least on the forum is box rise or impedance rise. But I'll do some research to see if I should start using impedance response instead if it is the official term used.
But thanks for the info. I explained it correctly but was using an incorrect term it sounds like but a common term to this forum.
BMW M340 xDrive
That's the problem, people keep using the wrong terms.
  • Who's Online   0 Members, 0 Anonymous, 879 Guests (See full list)
