Enclosure modeling, A little help ST 15" aero port.
aculous
https://web.archive.org/web/20130601145154/http://stereointegrity.com/index.php?id=60
T/S parameters for the Stereo Integrity 15" D2 sub
What do you guys think? Is a 20hz tunning way to low? should I change up the design?
Constricting factors are
Used in the calculator since it cut it off...
W- 30
L-20
H-22
Max:
Width- 38
Length- 38
Height- 22 (ish...could go higher but would rather not because its about 4-5 inches from the headliner)
I am looking for a simple ported enclosure with a aero port. If there is a different type of design that would be more efficient ON MUSIC then let me know. I could give two fucks about the meter.
One 3" aero port? No bueno.
Builds:
Depending on how much power you are going to run you could get away with a single 6" or even two 4" aero ports. Port noise and compression are what you are trying to avoid with more port area.
Also, there is nothing wrong with tuning to 20 Hz if sound quality is more what you are focused on. You will be leaving some SPL performance on the table though.
I'd probably shoot for more around 4 cubes net airspace too.
Builds:
alright that sounds doable, i may have to make the flares though. and leaving some spl behind is not a big deal. For power i am only putting 600w rms to tge sub so nothing crazy
To understand the advise you are given do some modeling yourself, it's a decent company and they provide the necessary infos to make reasonably correct use of your sub.
Well I am using Stereo Integrity's recommendations for volume and running freq. so I am not throwing that to the wind. And no I have not done much modeling yet obviously. Would winisd be the program that would be best for modeling different ports for this size enclosure.
20 hz is this a home theater
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 4861 Guests (See full list)
