jpsaudio Posted February 10, 2015 Report Posted February 10, 2015 is anybody really using these anymore or are people just charging secondary batteries. i havent drove my car in a few days and it has been really cold so i had to jump my car off the other day but the next morning i had to do it again and it just started doing that. i have a kinetik hc2400 in the back with 0awg fused from front to back. was it just to cold or do i need this isolator ?
Bump4life Posted February 10, 2015 Report Posted February 10, 2015 is anybody really using these anymore or are people just charging secondary batteries. i havent drove my car in a few days and it has been really cold so i had to jump my car off the other day but the next morning i had to do it again and it just started doing that. i have a kinetik hc2400 in the back with 0awg fused from front to back. was it just to cold or do i need this isolator ? if battery isnt starting the car, it means it is going bad. get it on a good charger and see if that helps. only thing an isolator will do is make sure that the system is only drawing from the rear battery so you can play it till it dies and still start your car off the fron tbattery to get home. if it were me id just montor voltage on both bats and start the car periodically if playing for long with car off. also charge batteries every few weekends. but sounds like your battery is going bad since it cant produce the amperage to start the car Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
never knows best Posted February 10, 2015 Report Posted February 10, 2015 the cold plays a big factor..... also if the battery is so low that it wont start you'l have to let the engine run or drive a bit to get a good charge on the battery... i'd suggest putting it on a charger before i'd go out buying new batteries- also check your grounds...
SnowDrifter Posted February 10, 2015 Report Posted February 10, 2015 HC2400 is a big battery. Not being able to start your car? Something's wrong. Disconnect both batteries entirely, charge them individually, then check their resting voltage after sitting for a few days. You can do this one at a time so you still have a battery in your car FYI. You also need to check for parasitic drain. Make sure EVERYTHING turns off when you leave the car. Dome lights, amps, under-hood light, relays, whatever ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
islandpride684 Posted February 10, 2015 Report Posted February 10, 2015 What kind of battery do you have in the front? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
jpsaudio Posted February 22, 2015 Author Report Posted February 22, 2015 come to find out that the rear battery was bad and it made the front battery bad took the cca from 885 to 170 so it crunk up as soon as i disconnected the rear battery but it died but i had a warranty on the front battery from napa so i got it replaced and im not buying used batteries from anybody ever again. im not even gunna put an amp on this battery until i do a full rebuild thanks for your input though guys
Skullz Posted February 22, 2015 Report Posted February 22, 2015 You'll be fine buying used as long as it isn't kinetik, you'll find good deals on deka's, xs powers and a few others worth buying used if you come across the right deal. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
