B2 Audio Serum 7K amp guts .
chris j m
the m1 is rated to do 7100 at 14.4
the serum 7 k is rated for 8500 at 14.4.
wether it will make these numbers I don't know .
the guy I bought this from said he had one bench tested and it did 8600 at 1 ohm ...
but I don't know the method or equipment he used .
Seems about right....the DC is rated at 7500@[email protected] and the DD is rated at 8350@1ohm @14.4.....the difference between the 2 is the DD is a low voltage amp with a 16v cutoff which I believe B2s are as well and the DC is stable up to 18v... DD also made the Z2-hv version of this amp( same board) but was rated at 7700@1ohm @14.4 but but capped at 18v like the DC
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Board says 2008. 03 rev:1
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
That's when the board was designed by the manufacturer.
yes
Like you said this amp was made for blade ice for sale in Europe.the m1s is the 7k amp. The m1 I believe is a 10k amp.
Nate I currently have 4 m1s and two that I've had almost 3 years with no yellowing. They def get dirty easier though.
Team B2
2008 scion xb bagged on 18's plastidipped matte black
4 18" b2 xc's pushed by 4 b2 m1s at .5 each
8 b2 hn6's and 2 b2 hntt's powered by 2 b2 quattros.
157.7 sealed so far.
