audiophile headunits???? where did they all go???
Nsomnia
This is why I consistently ask people not to add a processor until they learn what it is they need to process.
You can read all you want ... but there is no substitute for test and tune or trial anderror.
I could not make up my mind over silk or aluminium tweeters so I just got some AMT tweeters that state they can play up to 40,000 Hz
AMT = air motion transformer never played with em before and the reviews are awesome tho
It's alllll will's fault
Similar to PPI ones in the 3 way set?
Alpines now an sq snob
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
it is not cheaper
it takes up more space
it is not easy to tune (correctly)
yes you can change it on fly in some cases some DSP require a laptop i don't call that on the fly or simple tunning
and what if i told you ananlog done right will almost ALLWAYS sound better then a DSP?
are instruments digital or analog? what is SQ? the reproduction of LIVE ANALOG music just saying
DSP just made people lazy but i cant say to much on that every single car i have has a DSP in it im up to 3
i will admit i am lacking the skills to do an SQ analog build i need the crutch of a DSP
what would you consider a true analog setup? Full Passive? (by the way this is a honest question, I am not trying to bait. I am looking into a replacement for the 80prs, one of which would be a "active" crossover but I have yet to find anything that looks to be worthwhile except LP)
Also if you really get down to it a DSP can be more precise and allows more outputs that SHOULD be on modern headunits period.
Maybe this is ignorance but if I could find a 4-way crossover with coax and optical out connections I would be happy.
Lol where did you think I disappeared to ? Lol I went to the dark side of sq I won't even sit in a 150+ db car anymore j/k but sq is freaking awesome.....just sucks jumping in other people's cars most of there music makes me cringe now.... Ignorance was bliss
yeaaa...
not trying to knock anyone but the people who run all bass. And you literally can't hear the actual song...I mean its music people high mids lows, I need all three...
True analog would be class ab amps even tube amps even analog controlled eq's basically nothing digital even tho all CD s are converted to digital signal.
I have never put together a full analog set up we are in the digital age but the one I heard was amazing and fun to listen to..digital cars were more technical sounding the analog car was more warm and realistic sounding to me
The problem with the 80prs I am told and read everywhere the output signal I.e rca out put is crap for sq if you run a dsp it makes all the features useless with a lower grade output signal
Now if you are using for its features and don't have a dsp there not a deck out there that does it better.... And personally I think it looks like crap
  • Who's Online   0 Members, 0 Anonymous, 1279 Guests (See full list)
