Help with playing video, Pioneer AVIC-Z140BH
Skax
trying 480p video will post back in morning with results using .mpeg4 since apparently pioneer says thats all it supports
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
does it playback video through the ipod at all?
not using the ipod atm since i dont have the other 2 adapters it requires. and how do you go about lowering bitrate?
you can use a program like...
https://handbrake.fr/
Tried lowering to 480p and still get same error playing with usb :/ when I used to converter they still come out mp4
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Maybe it just doesn't support playing video from sub like said.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
idk wtf i said usb lol i meant sd card
Should've thought about looking on crutchfield >.>
Apparently it only supports video through a DVD.
Not sure if this is completely true as ive read around and heard of people playing through usb and sd and when i insert the sd card it says SD Video
You'll have plenty to listen to when you take a trip. This receiver plays music from CDs, plus CDs and DVDs loaded with music files. And listening to your iPod® or iPhone is as easy as plugging in to the rear USB port — you'll take control of your music from the receiver's touchscreen. If you need more audio options, check out the SD card slot and the rear A/V inputs. Again, you can play video content from DVDs on the main screen when you're parked, or send the video output to rear-seat screens when you're traveling.
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Found this if somone could explain exactly how i need to do it now lol
Below is what i have so far :D
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   1 Member, 0 Anonymous, 1283 Guests (See full list)
