Financial Mistake--Team Droppin' Hz--'10 Taurus Trunk Wall--Oval box COMPLETED--Video added (5/30/16)--DC Audio, PRV, Crescendo
20171112_011154
Well PHUCK! Hoping I can just get some more CA under it and respray the activator and get it to stick back down. I know it's my fault it did it, but I think the glue was going bad too so I don't know exactly who is at fault. Fingers crossed getting more CA down will do the trick.
I haven't had a ton of time to work on this thing. I did run into a small hiccup though. The cage didn't fit perfectly, but I also didn't account for the amount past the back of the cage the radio would stick out. I ended up having to cut out the top portion of the shape I had and then add a piece of foam and reshape it. Once I did that I taped over the entire shape and threw a layer of chop mat down over it. My plan is to let that layer cure and then pull it from the masking tape and then actually resin that shape down to the original shape and then reinforce it. Minor setback, but I'm in no huge hurry for it.
24709432828_60b76015f6_k.jpg20171122_083242 by [email protected], on Flickr
37864799664_632aeb5534_k.jpg20171122_084937 by [email protected], on Flickr
24709430908_a282403a09_k.jpg20171122_084949 by [email protected], on Flickr
38549293582_b3875168cb_k.jpg20171122_090403 by [email protected], on Flickr
So I've been holding back on some pictures and updates.
Friday I got the new headunit in.
24926264128_964f5c6ee8_k.jpg20171201_124437 by [email protected], on Flickr
38798729781_fba1e8cc16_k.jpg20171201_124833 by [email protected], on Flickr
And after a test fit, it didn't fit. I ended up having to cut slots in the shape again and reshape slightly, nothing too major though. While I was waiting on that fiberglass to set up I started working on the front section. I've made a lot of progress this weekend.
37900928505_aa7c73687e_k.jpg20171201_131624 by [email protected], on Flickr
23922489387_cddf67ce14_k.jpg20171202_081047 by [email protected], on Flickr
24914069968_28f6ab2460_k.jpg20171202_103900 by [email protected], on Flickr
23922486727_c5eda2eb9e_k.jpg20171202_103843 by [email protected], on Flickr
I'm gonna try and get the fiberglass sanded down and maybe get some filler on it tomorrow. Don't think I'm gonna be where I would like to have been, but I did make a lot of progress none the less.
Yea I was wondering about that when I saw you mocking it all up... looking good though! Can't wait to see it done!
05 TL build log SOLD
Youre on the right track dude.  I dig the motivation.
IG @walledsonic
Any updates on the woofer? Did you get it glued back down or you haven't messed with it yet?
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
It's still sitting at my buddy's house in his garage. I need to go get it. I'm assuming it will be OK. I made a rookie mistake when I did the recone. We Re-CA'd the hell outta the landing.
Keep pushing with secondary h\u, I'm definitely digging the idea.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
  • 3 weeks later...
So the mount has been put on the back burner for the moment due to the absolute bitter cold we have seen here recently, plus I want to get some input from my buddy who helps with my installs to make sure I get it right this time.
I've also got some big plans for this year. Subs will be changing. Pretty excited about the new ones that will be going in. I also got some pretty awesome news today going forward into this audio season. I'm gonna have a lot of work ahead of me to make a good impression.
