Smoove Posted March 10, 2015 Report Posted March 10, 2015 Soundquest (stinger) used to make a hybrid 70% CCA with 30% ofc 1/0. I have 200ft run in my build. I need another 50ft. People say don't mix cca and ofc wire like ofc for pos and cca for neg. So for my extra 50ft do I buy ofc or cca? This is a legit ask since the hybrid wire no longer exists. Some of the extra 50ft would be used for pos and neg runs. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Shenker Posted March 11, 2015 Report Posted March 11, 2015 Im not an expert on this type stuff, but logic tells me that as long as your not bottle necking the flow of current by using cca "upstream" of ofc you should not have an issue. the reason you shouldnt mix cca and ofc is because obviously ofc flows current better, so by feeding an amp or whatever it is with big current that is then slowed down by the cca neg wire you have created a bottleneck, and a potential heat source. so again I am by NO MEANS and expert on wire, but I would say if your ofc is only on the neg wires then have at it. -If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome. -"No way he's OCD." -said none of the people that know me ever. 04' Suburban "Lucifer" A.K.A #Lucii (Under Construction) 4 10s on 4kW in 6cu net @~28hz /////Alpine Crescendo KnuKoncepts Optima SHCA Build Thread 92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~ Gutted pipes 96,000 OG KM's (59,000 mi) -System Removed- 1 10 on 1kW 89' Gen 3 Honda Prelude SI AWS "Odis" Bone Stock Possibly going to stance it
Omega5002 Posted March 11, 2015 Report Posted March 11, 2015 Close enough?http://showtimeelectronics.com/shop/showtime-stca-1-blue30-30-foot-10-0-awg-gauge-blue-powerground-cablewire/ 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Smoove Posted March 11, 2015 Author Report Posted March 11, 2015 Close enough?http://showtimeelectronics.com/shop/showtime-stca-1-blue30-30-foot-10-0-awg-gauge-blue-powerground-cablewire/ I will order some friday. Thanks. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
rockFord_Expedition Posted March 11, 2015 Report Posted March 11, 2015 As long as the wire you add can meet your needs, there shouldn't be a problem. Yes, there will be resistance differences between the two but those electrons will find their way. Don't dissect this too much. Just make sure you have enough wire to carry the amperage you need, that simple bro. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Smoove Posted March 11, 2015 Author Report Posted March 11, 2015 As long as the wire you add can meet your needs, there shouldn't be a problem. Yes, there will be resistance differences between the two but those electrons will find their way. Don't dissect this too much. Just make sure you have enough wire to carry the amperage you need, that simple bro. I have more than enough already But just because I can I wanna add couple more connections. I just wanted to keep a hybrid wire all they way through. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
audiofanaticz Posted March 11, 2015 Report Posted March 11, 2015 I have ofc and cca mixed in my truck. No issues that I noticed. wires from each of the 3 alts to the front 2 batteries are ofc. wires from the 2 front batteries to the rear 5 batteries are cca (18 runs). wires from the 5 back batteries jumping each battery together are ofc, as well as wires from back batteries to amps is also ofc. as rockford_expedition said, as long as your cca wiring exceeds the maximum current draw you have, you should be fine. also if you stop and think about that you shouldn't mix ofc and cca wire together, then why are several companies doing just that with their "hybrid" wire?
Smoove Posted March 11, 2015 Author Report Posted March 11, 2015 I have ofc and cca mixed in my truck. No issues that I noticed. wires from each of the 3 alts to the front 2 batteries are ofc. wires from the 2 front batteries to the rear 5 batteries are cca (18 runs). wires from the 5 back batteries jumping each battery together are ofc, as well as wires from back batteries to amps is also ofc. as rockford_expedition said, as long as your cca wiring exceeds the maximum current draw you have, you should be fine. also if you stop and think about that you shouldn't mix ofc and cca wire together, then why are several companies doing just that with their "hybrid" wire? I know proper runs of either make it all good. I'm just anal about wanting it to be all hybrid and also wanted to see how many people are doing mixed runs like you are. I think runs like you have are educational to people who dont know better. Also another reason I started this thread Sssshhhhhhh!!!!! I already have some CCA runs as over kill along with overkill hybrid. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
CleanSierra Posted March 11, 2015 Report Posted March 11, 2015 You thinking about running about 15 more grounds? Im not the one you want to try to troll. Just a fyi for you.
rockFord_Expedition Posted March 11, 2015 Report Posted March 11, 2015 lol Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
