shanewargore Posted March 18, 2015 Report Posted March 18, 2015 Since I did not follow forum rules im going to change my thread. Should i cut my rear firewall for 1 15" or keep it as is for 2 10" here are the subs in question. If you can recommend better subs for under $200 go for it. I really want to make a trunk wall (sealing the subs from my trunk). also can anyone recommend bracing? I was think threaded rods but not sure how many and where to position them. Im working with Max dimensions of 35"x33"x14" . The rear firewall is only 11" x 28" so thats why i was thinking 2 10". any help would be appreciated. Specs TXX-BD3-10 Fs (Hz) 37 Re (Ohms) 2x3.6 Le (mH) 3.2 Qts 0.45 Qesv 0.51 Qms 2.1 Cms (m/N) 0.9 Vas (L) 16 Mms (g) 182 Mmd (g) 178 No (%) 0.2 SPL (dB-1W/1M) 87 BL (T*M) 25 Sd (cm2) 346 Krm (mOhms) 55 Erm 0.7 Kxm (mH) 102 Exm 0.67 Frequency Response (Hz) 24-1000Hz Voice Coil Diameter 2.6”/65.5mm= Voice Coil Height 1.5”/38mm= Voice Coil Layers 4 Magnetic Gap Height 0.47”/12mm Linera Excursion, pk-pk(Xmax) 0.51”/13mm Maximum Excursion, pk-pk 1.97”/50mm Magnet Weight 132 oz./4.1 kg Woofer Displacement 3.40 L/0.12 cubic ft. Net Weight 19.9 lbs./9 kg OR 1 15" Audiopipe TXX-BD3-15 tuned about the same in the trunk . Cant wall it unless i cut my rear firewall which i really dont want to do. Specs Fs (Hz) 30 Re (Ohms) 2x3.6 Le (mH) 6.2 Qts 0.47 Qesv 0.50 Qms 3.0 Cms (m/N) .63 Vas (L) 69 Mms (g) 388 Mmd (g) 373 No (%) 0.4 SPL (dB-1W/1M) 90 BL (T*M) 32 Sd (cm2) 850 Krm (mOhms) 38.6 Erm 0.75 Kxm (mH) 108 Exm 0.68 Frequency Response (Hz) 18-800HZ Voice Coil Diameter 2.6”/65.5mm= Voice Coil Height 3.3"/84mm Voice Coil Layers 4 Magnetic Gap Height 0.47”/12mm Linera Excursion, pk-pk(Xmax) 0.59”/15mm Maximum Excursion, pk-pk 1.97”/50mm Magnet Weight 220 oz./6.4 kg Woofer Displacement 4.53 L/0.16 cubic ft Net Weight 33.1 lbs./15 kg
ImaNoob Posted March 18, 2015 Report Posted March 18, 2015 What would be louder/ vs threads are not aloud here...Read the rules 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
Karkov Posted March 18, 2015 Report Posted March 18, 2015 It's not versus if same brand I think 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
ImaNoob Posted March 18, 2015 Report Posted March 18, 2015 Maybe...I got them warning post for the same type of thread..same brand. cary on..lol 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
Noel989 Posted March 18, 2015 Report Posted March 18, 2015 It's still a what's louder which it's not allowed theirs no "trunk wall" We can't tell you which one will be louder Only one way to find out and that's to build both Build Log - http://www.stevemead...-cruiser-el-pt/
shanewargore Posted March 18, 2015 Author Report Posted March 18, 2015 http://www.stevemeadedesigns.com/board/topic/148834-how-to-make-a-trunk-wall/ What would you call this? a box built and sealed at the trunk?
BoomZoom808 Posted March 18, 2015 Report Posted March 18, 2015 I wouldn't use either of those subs unless you already own them 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
shanewargore Posted March 18, 2015 Author Report Posted March 18, 2015 Is there a particular reason you wouldnt use them ? I mean besides the fact its AP?
BoomZoom808 Posted March 18, 2015 Report Posted March 18, 2015 Is there a particular reason you wouldnt use them ? I mean besides the fact its AP? because there are proven subs out there with twice the peak to peak xmax for less money? 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Joe X Posted March 18, 2015 Report Posted March 18, 2015 Yes 15 mm peak to peak Xmax is 7.5mm one way which is very little regardless of the price, go with something else, you won't regret it, on the sub diameter options, if the box can be 16 1/4" tall, go with a single decent quality 15", less drivers less cost.
