Flip_one Posted March 26, 2015 Author Report Share Posted March 26, 2015 Every other wiring connection is in perfect condition Link to comment Share on other sites More sharing options...
islandpride684 Posted March 26, 2015 Report Share Posted March 26, 2015 Talk about a tight fit, you know they make those gauge reducers...I would disconnect them shits ASAP...your power wire and ground wire are probably making out here and there... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
magillaru Posted March 26, 2015 Report Share Posted March 26, 2015 What Island said.....disconnect that NOW before that thing goes up in flames and get some reducers. Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
diegoclass2010 Posted March 26, 2015 Report Share Posted March 26, 2015 i had some jl audio amps that did the same thing, but it was my fault at the time, i was using 8 gauge wire and it would get too hot, but usually the real problem was my ground. i would never ground it correctly, meaning i would not use a bolt with a ring terminal or sand down the paint. i say check your ground, and get some 1/0 to 4 gauge reducers, that should fix it Link to comment Share on other sites More sharing options...
Flip_one Posted March 26, 2015 Author Report Share Posted March 26, 2015 So you guys think the reducers will fix the problem? I dont want to spend money on them and the wire will keep melting Link to comment Share on other sites More sharing options...
Flip_one Posted March 26, 2015 Author Report Share Posted March 26, 2015 I have a good ground for sure, I have a bolt and a nut and the paint sanded down. Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 26, 2015 Report Share Posted March 26, 2015 well they wont hurt none.. Who knows what is potentially arching where inside there.Plus they are only $19.00 for the pair. http://www.droppinhzcaraudio.com/toolmaker-1-0-to-4ga-reducer-w-offset-pair/ Link to comment Share on other sites More sharing options...
diegoclass2010 Posted March 26, 2015 Report Share Posted March 26, 2015 if your positive on that. how tight is that screw that holds wire at the jl audio amp?/ reducers will just help so you know you have a good connection and its not touching one another . but if its tight already it wont really do nothing Link to comment Share on other sites More sharing options...
Flip_one Posted March 26, 2015 Author Report Share Posted March 26, 2015 I just ordered a pair of Stinger 0-4ga reducers, hopefully that fixes it Link to comment Share on other sites More sharing options...
islandpride684 Posted March 26, 2015 Report Share Posted March 26, 2015 You need ones that are offset... http://www.droppinhzcaraudio.com/toolmaker-1-0-to-4ga-reducer-w-offset-pair/ Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
