JL Audio 1000/1 v1 amp melting wires problem
Flip_one
Talk about a tight fit, you know they make those gauge reducers...I would disconnect them shits ASAP...your power wire and ground wire are probably making out here and there...
i had some jl audio amps that did the same thing, but it was my fault at the time, i was using 8 gauge wire and it would get too hot, but usually the real problem was my ground. i would never ground it correctly, meaning i would not use a bolt with a ring terminal or sand down the paint. i say check your ground, and get some 1/0 to 4 gauge reducers, that should fix it
  • Who's Online   1 Member, 0 Anonymous, 1614 Guests (See full list)
