This is the build to get my Sundown X10's hidden under Bis-Kwik! Now a box build that is easy! But hiding 2 X10's and a bunch of Air Ride stuff was a JOB! Sure I could of put the box up top and more than likely it would hit harder but I still like to haul grocery's in this GROCERY GETTER!
Started off I had 2 cheap 10's under there with all my old air ride stuff. Sounded ok but I needed more! Most people have never seen this part of my build cause I did NOT show it off none!
Time to order parts and get started!!!
TIME to gut everything and figure this complicated build out!
I went with 2 air tanks this time a 5 Gallon & a 3 Gallon tank strapped together to fit in the spare tire area. Built all my mounting hardware out of aluminium. I'm now running 2 Viair 480c compressors as well.
Time for a box for them Sundown X10's now that I have the space & the Air ride stuff has been moved! 3/4 birch Ply wood with a Plexi-Glass window in the top to see the motors!
While I had the rear floor out I painted the carpet with Duplicolor carpet paint to freshing it up! NO-One makes a carpet kit for a Wagon so this is the factory carpet and is 53 years old so it had some miles on it!
Time to put it in and FINALLY bang!!!!
This is my current set-up! Wait until you see the one I'm working on now it should crush the X10 build!!!!
This Complete build is entered in this months SOTM contested #18 Sideshow_kustom If you like this build stop by the link and throw me a Vote! Thanks for taking the time to look & read my story!
http://www.stevemead...0-store-credit/
Times RUNNING OUT to get the votes in for ol Bis-Kwik for SOTM! If you like this build be sure to cast a vote for it! Also make sure to check out all my side stories to this build!
Be sure to cast your Vote for my build if you like it on the 24 Hour Flash Vote for SOTM! Also be sure to read all the side stories to this build in the links below! Theirs more to it then meets the eye!
Drive In Theater Speaker Build
Suitcase Build
Coleman Cooler Build
X10 Box Build
Complete Build Log On Bis-Kwik
NEW SUB'S 8 SundownAudio X6.5sw Build
What thickness of plexi did you use for the window? Acrylic or Lexan?
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
It is 3/4 Lexan. For it to be no bigger then it is it still get's some flex on it! I would of thought cause of it's size it wouldn't really flex but it does!
Same thing I'm using in my new build for the 8 X6.5sw's
Interesting. I'm planning a box with some windows, but they won't be nearly that big so I don't think flex will be as much of an issue. I'm thinking 1" acrylic, because acrylic can be polished if you scratch it and mine will be in the open.
2008 Subaru WRX STI
K&N Typhoon Intake
Cobb Accessport
MTX 421D Sub amp
3sixty.2
NAD 1020 Preamp
Let me know if you find some 1" for a good price. Every where I looked it was CRAZY high compared to the 3/4"! Don't make no sense at all! I would of rather ran 1" but couldn't find it for a decent price
This is where I'm looking, 12x12 1" thick for $24.59, 3/4" of the same size is $18.49. Best prices I've found.
http://www.estreetplastics.com/Clear_Acrylic_Plexiglass_Sheets_1_Thick_s/31.htm
2008 Subaru WRX STI
K&N Typhoon Intake
Cobb Accessport
MTX 421D Sub amp
3sixty.2
NAD 1020 Preamp
  • Who's Online   1 Member, 0 Anonymous, 1281 Guests (See full list)
