LsChevy Posted April 12, 2015 Report Posted April 12, 2015 I've noticed on just about every wall I see they all have a slot port. If aero ports are more efficient why people don't use those on wall builds?
tboorn Posted April 12, 2015 Report Posted April 12, 2015 its hard to find a aero port 20"+ in diameter and even harder to make them. and the ones you do find are insanely expensive. I've seen a few done and they were ones to remember for sure Fidelity Built to Last Team Sound Asleep 24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/ 2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3 2 DD M3b Maxwell 2.7V 3000F Supercapacitors Pioneer DEH-80prs Focal P165 V30 components Rockford Fosgate T-400.4
islandpride684 Posted April 12, 2015 Report Posted April 12, 2015 you didn't look hard enough...and plus like T said..it gets pretty expensive if you are trying to get one that big... http://www.psychoport.com/#!psychoacoustics/mainPage Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Joe X Posted April 12, 2015 Report Posted April 12, 2015 The slot can do the job just right as long as it's large enough.
LsChevy Posted April 12, 2015 Author Report Posted April 12, 2015 Will four 6" aero's be enough for three 18's or is it sub dependant?
Joe X Posted April 12, 2015 Report Posted April 12, 2015 It's sub dependent but that's too low for almost any 3 18s at full excursion. Just to give you a rough idea for average drivers, about 2 6" ports per 18" sub.
n8ball2013 Posted April 12, 2015 Report Posted April 12, 2015 I look at aeros I a. Few ways. You're eier a hard core street class competitor where you are limited in space. Or you're a noob who's too lazy to figure out how to build a slot ported box. Easy to cut a hole and stuff something in it. Most of the time slots add strength where an aero can never claim that THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
LsChevy Posted April 12, 2015 Author Report Posted April 12, 2015 What happened to aero's being more efficient than slot ports
Triticum Agricolam Posted April 12, 2015 Report Posted April 12, 2015 What happened to aero's being more efficient than slot ports The efficiency difference is easily made up by making the slot port bigger. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe X Posted April 12, 2015 Report Posted April 12, 2015 Slot ports usually develop turbulence at lower air speeds than aeros, so you increase port area to keep airspeeds low, that along with wood thickness of their internal walls make them larger and as a result your box will be larger. A large enough slot port can have comparable performance to aero ports for most applications.
