Hugh G. Rection Posted April 20, 2015 Report Share Posted April 20, 2015 If using bolts through the box, make sure you order some copper bolts, copper nuts, and copper washers online for it. Believe me, it makes a difference. Owner of BigAss Ports Link to comment Share on other sites More sharing options...
Orfeous Posted April 20, 2015 Author Report Share Posted April 20, 2015 Copper stuff will be overkill for me. This is a small setup with kinda small power.I think M4 bolt it will be then to fit my ring terminals 4.3mm holes inside rings.Bolt from inside. Nut on outside to hold the bolt in. Then ringterminals outside that nut and a nut holding the ring terminal? Ok?I requested pictures of some installs.. but i havent seen some. Pictures make me better understand. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted April 20, 2015 Report Share Posted April 20, 2015 http://lmgtfy.com/?q=bolt+terminals+for+sub+box That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
islandpride684 Posted April 20, 2015 Report Share Posted April 20, 2015 Copper stuff will be overkill for me. This is a small setup with kinda small power. I think M4 bolt it will be then to fit my ring terminals 4.3mm holes inside rings. Bolt from inside. Nut on outside to hold the bolt in. Then ringterminals outside that nut and a nut holding the ring terminal? Ok? I requested pictures of some installs.. but i havent seen some. Pictures make me better understand. Drill hole for bolt, place a washer on bolt, insert ring terminal, insert another washer, slide bolt through hole, insert washer outside of box though bolt, insert ring terminal, insert a washer, and last but not least thread nut, torque to 25 ft lbs....jk on the last part, hand tight is fine Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Orfeous Posted April 20, 2015 Author Report Share Posted April 20, 2015 I would prefer securing the bolt first so it doesnt fall in to the box if i want to remove the cables for some reason. Why all washers? Link to comment Share on other sites More sharing options...
islandpride684 Posted April 20, 2015 Report Share Posted April 20, 2015 I would prefer securing the bolt first so it doesnt fall in to the box if i want to remove the cables for some reason. Why all washers? Do it however you want to... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted April 20, 2015 Report Share Posted April 20, 2015 Threaded rod with a washer and nut inside and out then put the terminals on and secure with with another nut tightening them up to the first nut. It's not rocket science here, it is literally as simple as tightening a nut. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Orfeous Posted April 21, 2015 Author Report Share Posted April 21, 2015 Thanks for all advices! Rebuilding the box in about two weeks. Link to comment Share on other sites More sharing options...
sirhutson Posted April 21, 2015 Report Share Posted April 21, 2015 Just use 12 gauge yea? boss 1200 and a ipod nano. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 21, 2015 Report Share Posted April 21, 2015 Just use 12 gauge yea? ^^ kinda wondering why the need to use 8g. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
