well that will largely depend on how you are planning on making that power. a single 4k amp at 1ohm won't have the same requirements as a 2k amp at .5ohms
give us the amps and voice coil configs and someone can help you out.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
not dogging on the amps at all. i'm just saying any two 1.3k amps won't get you 4k...anyway...
so you are going to be running them one amp per sub at 1ohm?
F150:
Stock :(
Processor: DSR1
If you want 4k you should get amp rated to do that! There are lots of options! :)
Strapped at 2ohm. So 1ohm on each amp. I may try lower load down the road after my electrical is stronger.
dual .5s then for subs? that will get really low real quick.
or do you mean reconing?
Either way I hope someone who knows how to calculate draw will help with your alt question, I should have said from the beginning I don't know how to do it.
F150:
Stock :(
Processor: DSR1
Plan for the max current demand you could possibly see even though it's very unlikely to ever be that high.
4k at 14 volts Is 285 amps of current the lower your voltage go's the higher the current demand is.
This also isn't accounting for many other things so.....
Also typical car audio math in here, 1300 + 1300= 4000.
Even if you bought a 4k you'll never get 4k out of it.
Looks like 1500w per sub, 3,000w is what he is going to get if he can maintain 14v while both amps are pulling power, but that is not going to happen on a 105A stock alternator is what they are saying. You need something like a 260A alternator to maintain a system like that. You will need a lot more than just an extra battery to supply the juice you need for a system like that. Instead of putting more money into wiring, you need to start looking around for a quality high output alternator.
