Silverado charging issue
Just recently my 2007 silverado classic started to charge higher than normal 15.2. I have a dc270. Not very old. Took big 3 wiring out and still does the same. My buddy has a 2005 with th same alt. his has been doing this for a month. We can't figure out why. If this continues I will be tearing everything out and selling
Was that year PCM controlled? If not maybe the regulator in the alt going bad? Do you still have stock alt to see if the stock will have high voltage as well? maybe try putting a load see what happens.
On a different note what you got for sale?
If it's worth building, it's worth over building.
For everybody with PCM controlled alts in gm. 05+ Tahoe/silverado ect. When you do the big 3 you need to run your big 3 ground through the GBCM. It's a sensor ring right next to the battery that measures some kind of current to regulate the charging
what if you've bypassed the pcm( internally regulated) do you still have to do this?
Interesting, I need to look more into this. Any chance you could post a pic of what you're talking about?
97 Suburban
8 custom PSI Platform 3 18's
One time when I was working on my alt, I had connected the lead that turns the alt on (the one that comes from the battery into the alt plug), then disconnected it, and the voltage shot up to 15.2. I don't know if that has anything to do with what is happening to yours though.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 3434 Guests (See full list)
