sundownaudio Posted June 6, 2015 Report Posted June 6, 2015 can i use a acetylene torch to solder 1/0 wire ? and would the heat damage the wire ? the flame is on low
prodigal_son Posted June 7, 2015 Report Posted June 7, 2015 My friends and I have a saying....be smarter than the tool....Of course you can use an acetylene torch to solder with, even oxy acetylene, just apply the heat judiciously. If you are proactive and apply the solder as soon as the fitting is hot enough, you'll never come close to damaging the wire.
TaylorFade Posted June 7, 2015 Report Posted June 7, 2015 How about this... Crimp them properly and don't use solder at all
Tarball Posted June 14, 2015 Report Posted June 14, 2015 I use a MAP torch. Proper crimp is fine too. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
RooTxBeeR Posted June 14, 2015 Report Posted June 14, 2015 Because some people don't have access to a few ton 1/0 crimp press when they have access to cheap gasses. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
