Alternator Whine issue *figured out* UPDATE pg.11
Yeah I have a monoblock I could try out. Would that work?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Here's something to try. Instead of putting a monoblock on kids and highs....
Your "hiss" is coming through your mids and highs only, not the subs, correct? Via the 4-channel amplifier. And the hiss is there even when you have no music playing correct? So wire your subs up to the 4-channel, open up all filters so it's full pass of frequencies to the subs, but don't play anything, and listen for the hiss. If you have a garage where you can block out outdoor noise, that would be the best place.
If you have the hiss, it's your amp, if you don't, it could still be your amp but my idea didn't work due to the frequency range of the subwoofer(s).... :(
I know everyone situation is different but I just recently picked up a bad alternator whine, kicked my ass looking for what was going on! Then my front channel went out on one of my amps. The whine went away, don't know if the whine started cause something failing in one of my amps and back feeding to my HU but its gone now! Hope you find it and it ain't an amp going bad like mine was!
I had the same thing just happen to me.
So I grab an old Polk Audio 400.4 and run it temp setup till I get all my gear for build and....
Had some whine and a day later left front channel on amp dead and whine was gone.
The only speaker output out of the amp that was bad was LF+ so I just just bridged both front and it works
while running fronts off rear channels.
But this dude has clean signal at the amps and through the rca's from front to back.
Check for distortion from head unit rca outs I guess??
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
I have a no volume hiss now, lol my amps about to die! LF+ out put dead and all crossover section dead so running it full open no crossover.
Current build
300amp alt
I have a X15 sitting in the house I can try this one. I'll see what happens.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
have you tried lowering your gains? If you are hearing a hiss when there is no volume, your gains are probably turned up to high
All of the gains are set with the DD-1. I have even tried lowering them a bit off of the point the DD-1 recommends and it's still there.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Just take the amp back and ask them to test it, make a short video on what it's doing. and wait for the response.
I emailed DroppinHZ and they said they could send it to Crescendo to have them test it. That would probably take a few months so if that's the case I might just try to sell the amp and buy another one. I also have a guy that wants to buy my car so I might not have it in a month. We will see though.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I bought the nendo 1100.4 and had noise issues, i never ran an amp this big on mids and highs and never had wine problems. I purchased it from crescendo website,and i sent it back to get checked out. meanwhile i bought a dc 175.4 from sonic , cause it matched the dc9k i was running. Same noise problem was there with the dc amp. I also tried grounding the head unit, got some high fidelity rca"s from dropping hertz. the noise is still there, just thought i would share cause i wasted a lot of time and money buying a new amp, when the problem is obviously somewhere else in my install.
  • Who's Online   0 Members, 0 Anonymous, 4405 Guests (See full list)
