reedal Posted June 23, 2015 Report Share Posted June 23, 2015 SMD IM-SG You got a response on how to measure impedance rise SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Wicks Posted June 23, 2015 Report Share Posted June 23, 2015 SMD IM-SG You got a response on how to measure impedance rise Buy, rent or borrow an impedance meter and sweep your (OP's) system. You can design a great box on paper, but the parameters will change when its installed in a vehicle (mine did). This will give you the best idea of how your system responds to various frequencies and what the amp can expect. Of course the parameters will also change at high power/temperature and other changes, but metering your impedance will get you the best basic view of what the amp is going to actually see. For instance, on paper my system was tuned to 37Hz and I'm wired to "1ohm". Real world, I'm tuned to 32Hz with a low impedance of about 1.78ohms. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
mothra Posted June 23, 2015 Report Share Posted June 23, 2015 run it and see what happens. if it keeps going into protect, you know it's b/c the impedance is too low. if it works, than it works. seriously too much of what works is b/c someone tried it. no matter what you post, it won't matter what people say b/c none of us have your products so we can't try it. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
Miguels Posted June 23, 2015 Report Share Posted June 23, 2015 Another thing is.. Just because it worked for someone else its not going to work for someone else.. Electronics are a bitch. Some have better luck than others my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
SLYentist Posted June 23, 2015 Report Share Posted June 23, 2015 the ratings are only a nominal impedance Cables and wires almost never fail; the terminations do. Link to comment Share on other sites More sharing options...
graham0599 Posted June 23, 2015 Report Share Posted June 23, 2015 I wouldn't suggest running the amp below what it is rated but there is cases of people, including myself, doing it and it working for a long time. A DD-1 can definitely help, correct gain setting can save equipment. You have to know the limits of the equipment, if you choose to push past the ratings, you're accepting the inherent risk. As far as measuring impedance rise, your best bet would be an IM-SG or a multimeter. My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
Csprak1990 Posted June 23, 2015 Author Report Share Posted June 23, 2015 Appreciate the help, I'm investing in a SMD DD, and I have a cheap dmm but not a clamp meter. In all honesty the difference from 4 ohm to 1 ohm wasn't too significant compared to risk vs reward ratio. I just wanted a reason to try it lol. But I appreciate all the help. Link to comment Share on other sites More sharing options...
reedal Posted June 23, 2015 Report Share Posted June 23, 2015 That little bit of power difference between ohm loads won't really sound much different if at all. It takes a substantial increase to notice a difference once you get around 2000w it seems to me. Wanna get louder? Add more cone area. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Csprak1990 Posted June 23, 2015 Author Report Share Posted June 23, 2015 Well im in a accord the trunk size is nice but I got a box around 5-6 cubes but about 4 cubes of useable airspace. And takes up entire trunk. Plans are for 4 x-10s but im broke. So I got 4 e-10s right now. About 142 dbs @ headrest on term lab. Its a daily driver not competition. But i do want to get louder eventually just not looking into doing a wall since I got kids. But im sure all yall will be there to help when I plan on getting louder. Right now just reading and learning. Link to comment Share on other sites More sharing options...
