Home network help.
Here's what I've got.
Thanks a ton for that other site otherwise I would've been double the cost. As far as I can tell the switch is 10/100/1000 on all ports. Do u see anything I may be missing?Screenshot_2015-07-06-08-23-52_zpsec1pbsScreenshot_2015-07-06-08-26-12_zpsjf7uuu
And here is the one I have. If nothing else I can sell it if it works on other networks and have Mediacom send us a different one.Screenshot_2015-07-06-08-44-49_zpssdeyyb
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Parts list looks good.
Switch looks fine.
I know nothing about the Arris.
Is the Arris just for VoIP (telephones only) all the photos of it i can find show only one ethernet port for a incoming/outgoing connection.
Under Construction
It was supposed to be a 2 in one. But after calling and activating it I found they charge like $5 a month to activate the WiFi feature. So activated the old one
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Seems cheap enough. I'll just have to figure out how to set it up.
Would u wire that in or stand alone?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I would wire it KiKaZz74, but you could try it wireless and see how it works. Should it not perform well setup using wireless you could always run a cable out to it.
MrSkippyJ he needs a switch because he is going to have more than 4 devices hardwired.
Under Construction
So I didn't read really deep into this but from my experience hardwiring your network is always the best idea.
No matter what you do wireless won't be perfect unless you add a lot of equipment and money and thats a PITA.
So not sure if anyone mentioned but a router and a switch are pretty similar in what they do, a hub is not. A router and a hub would most likely be what you are looking for. Basically the router assigns IP addresses to your devices and hub acts only as a connection point, getting IP addresses from the router, whereas a switch can assign IP addresses as well. A hub or a switch will both work, I would just get a hub because its going to be cheaper and your router will be doing the heavy lifting anyway.
I would run all gigabit equipment, cat5e or 6 can support it, go with cat6 if you can. Also instead of doing big cable runs you can do powerline adapters which are super convenient and decently fast.
https://www.netgear.com/home/products/networking/powerline/
I use powerline adapters to get from one floor to another and run full gigabit from there.
On a side note, probably need to upgrade your router. I would go with one with full gigabit on it and probably a netgear prosafe or some type of commercial grade router if you can afford it. I got mine for literally the same price as the consumer model and has lasted for years as well as having some nice networking options. Also I could sell it on ebay if I want for half price 10 years later. Not to bad.
I'm late to the party!
I do cabling, networking, and IP-based surveillance for a living.
Do you have any other questions, KiKaZz74? I may could clear up some unanswered questions.
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
  • Who's Online   0 Members, 0 Anonymous, 484 Guests (See full list)
