illestVillian Posted July 5, 2015 Report Posted July 5, 2015 03 tl still loses voltage only when driving / braking. It will sit and idle fine. So I have a new xs power d2400, Mechman 240, big 3, Pioneer 80prs. Took it to 2 different places and no one knows why it drops voltage when driving. I checked the grounds and all connections. But I'm thinking of adding additional grounds. I took the 2 stock 4 gauge off because of corrosion and just replaced it with 1/0. most people say leave it and just add to it when doing a big three. I have new 4 gauge I can throw on, should I swap the stock back to 4 gauge and make new runs of 1/0 ? Or can I just double up on the same ground location with 4 gauge on top of the 1/0?
Rich Schenk Posted July 9, 2015 Report Posted July 9, 2015 Where our you grounding too? Frame, shock tower, stock location? Our you u grinding down to bare metal? Use dielectric grease On all your connections. Always leave stock grounds alone just add more grounds. Do the big 4 On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
n8ball2013 Posted July 9, 2015 Report Posted July 9, 2015 Because it's a Honda. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
n8ball2013 Posted July 9, 2015 Report Posted July 9, 2015 That's not a dig btw. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Leo1103 Posted July 9, 2015 Report Posted July 9, 2015 Voltage on honda's is controlled from the factory by the ELD, it can vary your charge voltage anywhere from 14.4 to 12.6 volts. There are ways to bypass it, however the easier way is to get a 1 wire turn on internally regulated alternator with a harness that allows it to keep the stock plug. You will most likely have a battery light from this but the voltage should be consistent. 2002 Honda CR-VAlpine 9887My BuildRebuilding... Second Skin Damp 4 DC XL 15's 2 DC 5ks Singer 320 amp 6 cap banksSky High wire 2 VM-1's OM-1 all under window line Team DC Audio Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.EDIT: Not in a JP kind of way. I thought I was going to die from all the jizz filling my ears.
illestVillian Posted July 10, 2015 Author Report Posted July 10, 2015 I have seen a eld bypass video recently for Hondas. Seems like a fire hazard, plus that's a little out of my league as wiring is concerned. And no I didn't use and electrical grease on my connections. I did however wire brush down the bare shiny metal. This all started when I did my big 3, my voltage was always 14.4 no matter what. Since, with my new Mechman alternator and new XS Power Battery I can't hit 14.4 volts anymore. The highest I will go is 14.2. This is driving me nuts, I wish I would just get a check engine light or something to pinpoint the problem. I had better voltage with my stock 110 amp alternator and my old shitty battery. Who knows! Thanks for replying guys!
illestVillian Posted July 10, 2015 Author Report Posted July 10, 2015 I having trouble locating the eld on my 03 tl. Montgomeryville Acura said they sell me the fuse box with that in it for $220 or around that. Seems like a lot of work to do and might have something else fuct up in the process.
Leo1103 Posted July 10, 2015 Report Posted July 10, 2015 I bypassed it in my car and it was still being a bitch, talked to singer and he redid my alt. All I do is plu his harness into the stock one and then into the alt and I'm at 14.6/14.9 all day and 15.2 when its cold. 2002 Honda CR-VAlpine 9887My BuildRebuilding... Second Skin Damp 4 DC XL 15's 2 DC 5ks Singer 320 amp 6 cap banksSky High wire 2 VM-1's OM-1 all under window line Team DC Audio Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.EDIT: Not in a JP kind of way. I thought I was going to die from all the jizz filling my ears.
Kyblack76 Posted July 10, 2015 Report Posted July 10, 2015 I bypassed it in my car and it was still being a bitch, talked to singer and he redid my alt. All I do is plu his harness into the stock one and then into the alt and I'm at 14.6/14.9 all day and 15.2 when its cold. Mike dont know what hes doing........ last thing id recommend... edit- eld love did NOTHING for my acura either... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
