justin0943 Posted July 16, 2015 Report Share Posted July 16, 2015 heres the .5 ohm test 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/ Link to comment Share on other sites More sharing options...
SQSPL50 Posted September 15, 2015 Report Share Posted September 15, 2015 Anyone reached a verdict yet? Link to comment Share on other sites More sharing options...
Moreno93 Posted September 15, 2015 Report Share Posted September 15, 2015 As broke said i'd stay away from it. They probably put like a 4K board in one & did amp dyno on that amp. Therefore making it pass. The price just seems to low, therefore they sacrificed something & the brand name alone sounds like swapmeet trash. Steer clear untill they've been around for a couple years, if they make it that long Link to comment Share on other sites More sharing options...
g2shuck Posted September 15, 2015 Report Share Posted September 15, 2015 Looks like two videos edited together to me. Watch close. Amp stops at 1031 watts and a crazy 16.01 volts with distortion light on (certified is to distortion) and Dyno temp is 77 degrees. Then video flashes, power says 1856, 14.64 volts, and Dyno temp is 76 degrees with distortion light off. So in less than one second how does it instantly flash up 825 watts, down 1.37 volts, lower the Dyno temp which should be heating up, and magically stop distorting. https://m.youtube.com/watch?v=IkOLqEDSsXk 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member Link to comment Share on other sites More sharing options...
g2shuck Posted September 15, 2015 Report Share Posted September 15, 2015 Also every Dyno cideo I've seen in certified climes not jumps around. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member Link to comment Share on other sites More sharing options...
KMS Posted September 15, 2015 Report Share Posted September 15, 2015 Too good to be true. Buy at your own risk, buyer beware, need I say more? Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT Link to comment Share on other sites More sharing options...
SkarredSierra Posted September 15, 2015 Report Share Posted September 15, 2015 If your really interested buy one from somewhere online where you can return it then test it and post a real vid here. If its not up to specs send it back. Link to comment Share on other sites More sharing options...
8v fury Posted September 15, 2015 Report Share Posted September 15, 2015 I might buy one or two and see how they last and perfrom for a whole year. Pushing it to the limits. Want more power. Link to comment Share on other sites More sharing options...
SkarredSierra Posted September 15, 2015 Report Share Posted September 15, 2015 If you do get some make sure to dyno and post a vid. It would be interesting to see what one can do. Link to comment Share on other sites More sharing options...
300824 Posted September 25, 2015 Report Share Posted September 25, 2015 get what you pay for in the audio world!!! Link to comment Share on other sites More sharing options...
