Age old problem need advice
I got a 96 Accord with JL Slash 1000 watt mono amp and a slash 300w 4 channel, 180 amp alt and die hard platinum battery (yes I've done the 'big 3' and did the mod to get full output from the alt). I still get light dimming problems. I guess the next step is a second battery in the trunk. I want to take up as little room as possible. What equipment should I get and how do I do this right?
Super caps=good
Regular car audio caps= bad
RESULTS:
No Capacitor:
1543 Watts RMS @ 13.80V into 4 ohms
2550 Watts RMS @ 13.32V into 2 ohms
3154 Watts RMS @ 12.76V into 1 ohm
With 1 Farad Capacitor:
1613 Watts RMS @ 13.98V into 4 ohms
2666 Watts RMS @ 13.60V into 2 ohms
3426 Watts RMS @ 13.35V into 1 ohm
With 100 Farad carbon supercapacitor:
1620 Watts RMS @ 13.95V into 4 ohms
2616 Watts RMS @ 13.65V into 2 ohms
3260 Watts RMS @ 12.91V into 1 ohm
why are you worried about your lights dimming ?
and what alt do you have in a honda that does 180?
swap to hid's and you wont dim..
I do dig those slash amps btw
edit - putting more reserve may help.. but... ..... the speed of the low end note hitting,.. a cap may be what you want..... a proper one.
or just put in HIDs if your that worried about dimming...
Have you put a meter on it while playing?? (ill bet your holding fine voltage)
Just so we all know a cap of any kind is not going to stop them dimming and most likely neither will a battery.
My voltage drop was around .1-.2 and my lights still dimmed, like kyle said if it bothers you get hids.
