Age old problem need advice
Do you know how much voltage drop you are getting?
Also I've seen multiple people say the eld bypass didn't work.
Mine is working. I didn't fully explain myself either. I would like to get the dimming to stop but also when I have the volume too high my 300/4 will cut out due to low voltage. I can play the system pretty loud but if I really crank it up I have the problem.
the 1 farad caps work. they dont have to be super caps.. on the test they used a regular cap and yield the best numbers
here is the reason why lights dim... when the bass hits it takes a bit for the alternator to sense that voltage drop. by the time it puts out the amperage its too late. even high output alternators will have light dim. a cap works because it supplies a quick burst of power. a cap releases the energy faster than a battery thats why it helps
What is your voltage starting at and dropping to in numbers?
saying it gets low doesn't help us help you.
What is your voltage starting at and dropping to in numbers, saying it gets low doesn't help us help you.
i will take a wild guess and say he didnt tune the gains correctly and is clipping the signal.. i had my stock alternator with a group 78 and 2 group 31 on a DC 5k and i had almost no drop. if i can find the video i will post it
Think you need to realize, some cars lights dim even at mid 13v. Do you even have voltage monitoring when your are bassing?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • Who's Online   1 Member, 0 Anonymous, 1702 Guests (See full list)
