wiring loose
Can someone tell me if that looks bad?
Is that a serious question?
Hell yeah that's bad.
You need to be less worried about how much power you're getting and more concerned with starting a fire.
Singer Alternators
Team Asshole
#anothershittysingerbuild
www.bcae1.com
Go educate yourself. Please. Before you catch your car on fire. Loose/broken connections cause resistance, resistance causes increased heat, excess heat leads to fire.
If you don't want to fuse that wire that's on you. But with how shitty your electrical connection is there, I'm sure it's the same everywhere else, asking for a short and causing a fire. Fusing that connection will prevent the entire wire catching fire if there's a short.
My advice, disconnect everything. Educate yourself a little bit from the site I linked, and then once you have a basic understanding of how dangerous your setup is, get someone with experience to help/teach you how to install and set everything correctly.
  • Who's Online   0 Members, 0 Anonymous, 831 Guests (See full list)
